September 15, 2026, 04:19:04 am
Hoffman Amps Forum image Author Topic: diagram or layout for tremolo mod in a blackface super reverb  (Read 4653 times)
Offline stringbender.dk
« on: October 04, 2016, 02:04:30 pm »
Hi!
I asked for a couple of weeks ago how to make the intensity deeper, after the "hoffmann mod" I found here on the webside.
Some of you said it could be done by using a LED.
a tech did the LED mod. but the intensity did not get any deeper he said. but as a side effect the speaker started to move heavy in the same tempo as the tremolo and made a helicopter sound.
Is this how it should be, or do you have any diagram or layout on how to wire the tremolo mod????
Thanks, and take care
Re: diagram or layout for tremolo mod in a blackface super reverb
« Reply #1 on: October 04, 2016, 02:57:07 pm »
This should get you going...
EDIT... pic updated per Willabe's suggestion. Thanks.
« Last Edit: October 04, 2016, 04:23:27 pm by sluckey »
« Reply #2 on: October 04, 2016, 03:03:50 pm »
Sluckey, maybe add the LED color and voltage/current that works best to your notes list?
« Reply #3 on: October 04, 2016, 03:42:39 pm »
Thank you very much!
I link this to the tech, and see what he finds out  :)
« Reply #4 on: October 05, 2016, 06:59:32 pm »
Size and mA of LED should not be critical. (You can't buy an LED of too low mA, and size is just bulk plastic not the actual LED chip.)
Color (actually voltage drop) is key. White drops too much. Red is an excellent bet. Green is a bit more bias but may be fine also.
