August 29, 2026, 03:03:05 pm
Hoffman Amps Forum image Author Topic: Which is yours secret ? (I mean perfectly straight rheophores on yours works)  (Read 7457 times)
There are some of you, the first that must be mentioned is Doug
that realizes board with components with perfectly straight rheophores, this gives a fantastic look to the layout
Is this due to a patient work with pliers or you have a secret technique to do that ??
« Last Edit: October 13, 2016, 08:44:38 am by kagliostro »
What's a reophores?
Offline VMS
Maybe he meant rheophores.
from wiktionary:
rheophore ‎(plural rheophores[/b])(obsolete,[/i] physics) Any wire, electrode or connector that conducts electricity
Ciao Steve
Sorry if I've used a wrong term
rheophores = reofori which is the correct name in italian,  rheophores is the translation I get with google translator
(I put it correct in the title and wrote reophores on the text)
How do you call the "legs" (llittle pieces of wire to be used for connections) of resistors and capacitors ?
@ VMS
that is (but here refers to the "legs" of components)
« Last Edit: October 13, 2016, 08:46:23 am by kagliostro »
I just call them wires if they leave the board and connect to an off-board component such as a tube socket. If it's simply a connection between two components on the board, I call it a jumper.
I don't recall ever hearing that word before.
Offline p2pAmps
    • p2pAmps
I call that kind of work "Pride" in what you do.  To me, its all the things people can't see.  Good thing I'm not a tech for a living!
Everything Affects Everything
No, not the wires that go from board to sockets or jumpers
I mean the small wires that are part of the components like resistors and capacitors
« Last Edit: October 13, 2016, 08:53:01 am by kagliostro »
Offline VMS
Component "legs" are called leads.
Ah, OK, Leads
So now, which is the technique you use to have it perfectly straight ?
A lot of patience and pliers or what elese ?
Vms was faster!, leads, or legs, in the 'ol days I called it "lead dress".  they make "crimping" tools to straighten the legs, forms to get the nice radius bends.  P2P got it, pride, or workmanship, the difference between a B+ or A in school.
Ciao Shooter
I know the tool to bend leads, Doug sell it, but I was wondering about to have it perfectly strigh for our builds
with turrets or eyelets
« Last Edit: October 13, 2016, 09:17:13 am by kagliostro »
Ah, now I finally understand. I call those leads or sometimes legs. Those TO-39 style 8 leg op amps make some cute little bugs with 6 legs and 2 antenna. :wink:
Yes, as you say
Here the original
 :l2: :laugh: :l2:
« Last Edit: October 13, 2016, 09:11:35 am by kagliostro »
Offline VMS
Doug sells a lead bender tool that could be helpful.
Scroll down this page:
http://el34world.com/charts/toolhowto.htm
For me it is using new components and hoping I get it right the first time.
but I'm not asking for that, see Reply #10
p.s.: I've a lot (really a large quantity) of capacitors that are new but has the leads all crooked
« Last Edit: October 13, 2016, 09:16:23 am by kagliostro »
Some/most on line parts suppliers send the parts in a plastic bag that they have to bend the leads some to get them in.
I use a smooth jaw flat nose pliers to straighten the leads. It's a pain in the......  :laugh:
Mine are similar to these below.
« Last Edit: October 13, 2016, 12:01:33 pm by Willabe »
can't find any ol pic's from back when, like Steve said, these were fun, bend some R's around, some wire, couple caps and you had functioning art.
« Last Edit: October 13, 2016, 01:17:10 pm by kagliostro »
Offline jim
There is often a flat section on many needle nose pliers that can be used.  Check yours...maybe another tool is not necessary.  I draw the lead through the flat with minimal pressure on the plier. Rotate. Do it again.  It is easy to pull leads out of the rolled yellow metallized paper caps and also small value polystyrenes so be careful. Jim
Thanks Jim
