August 29, 2026, 03:04:34 pm
Hoffman Amps Forum image Author Topic: tone stack losses  (Read 6914 times)
Offline 12AX7
tone stack losses
« on: November 15, 2016, 09:06:48 am »
I have a effects loop that is fed from the cathode follower in a marshall style amp, so the tone stack feed is AC. When i inserted a signal, at the TS input and check the signal level at the input of the TS then at the treble wiper output, i get about 45% of the input signal at the output with the tone controls all on 10. Doesn't that sound about right? I'm just trying to eliminate all possibilities to find a issue i'm having so i just want to confirm that this is typical. Thanks.
Re: tone stack losses
« Reply #1 on: November 15, 2016, 10:26:59 am »
Use the Duncan Tonestack Calculator.  Also without a schematic your question requires too many assumptions to answer.  BTW all tones tacks are always fed with AC.  All signal is AC.
« Reply #2 on: November 15, 2016, 11:05:40 am »
Offline 12AX7
« Reply #3 on: November 15, 2016, 11:17:10 am »
I have the TSC.
As to DC vs AC....if a cathode follower is AC, what could cause mine to output DC? Because thats what i reads stable.
« Reply #4 on: November 15, 2016, 12:06:46 pm »
D.C. is always present at the output of a tube stage (before any coupling capacitance) to allow the tube to function. A.C. is present at the output when a signal is applied, and transferred from input to output.
The output of any tube feeding a tone control circuit often has no extra coupling cap to block d.c., because the tone circuit contains caps already which can then serve double-duty to block d.c.
... When i inserted a signal, at the TS input ... i get about 45% of the input signal at the output with the tone controls all on 10. ...
PRR's plot shows 45% output happens at 3 frequencies.  One of those is very-near 1kHz.
I'm guessing you used a 1kHz test tone...
« Reply #5 on: November 15, 2016, 12:07:05 pm »
The output *at the cathode* will be several volts AC/Audio riding on maybe 150V of DC.
The output *after the tone stack* should be AC/Audio and zero DC.
Say what your real concern is.
Offline 12AX7
« Reply #6 on: November 15, 2016, 12:29:03 pm »
I see. And yes, a 1khz tone.
Offline 12AX7
« Reply #7 on: November 15, 2016, 12:32:15 pm »
I already posted about it but got no responses so i deleted it because i figured no one had any advice on it. So i decided just to ask questions about ideas i had to try and troubleshoot it myself. So no reason to post about it. I just wanted to get this question answered and it was, thanks.
« Reply #8 on: November 15, 2016, 12:44:35 pm »
All the resistors and capacitors in a circuit present an AC-load (to the signal). The more resistors (and/or caps) there are in parallel, the higher the AC load (and the more signal attenuation there otherwise is).
