August 29, 2026, 03:04:35 pm
Hoffman Amps Forum image Author Topic: Re: Hoffman AB763 one and two channel Turret Boards  (Read 4803 times)
Offline Sonny ReVerb
  • Possibly another stupid question...
« on: November 15, 2016, 03:21:12 pm »
Just wondered about two changes from stock AB763 schematics.
Why did you choose an 0.0022uF for the cap off the plate of the reverb recovery (C19) instead of the usual 0.0033uF?
And why a linear taper pot for the tremolo intensity instead of audio taper?
« Last Edit: November 15, 2016, 06:11:54 pm by EL34 »
« Reply #1 on: November 15, 2016, 06:21:17 pm »
I am seeing a .0033 here
http://el34world.com/Hoffman/files/Hoffman_AB763_2.pdf
The notes on the library page show that this is a different trem/vibrato ciruit
It's a bias wiggle circuit, not a opto isolator circuit
http://el34world.com/schematics.htm#Hoffman_AB763_Two_Channel_
Check out all the documents for the AB763 board on the page above
« Reply #2 on: November 15, 2016, 06:33:44 pm »
The cap C19 is a .0022 on the single channel pdf and it's a .0033 on the two channel pdf. Blame it on Visio.  :icon_biggrin:  I really don't think it matters which value you use.
« Reply #3 on: November 15, 2016, 07:49:43 pm »
Thanks, guys. I just wondered if that was a particular design decision to 'improve' the reverb.
As for the tremolo intensity pot, I noticed the Vibroverb 6G16 trem uses an audio pot and the Vibrolux 6G11 uses a linear pot. Hmm...
And yes, I'm looking at the one channel AB763 schematic:
http://el34world.com/schematics.htm#Hoffman_AB763_One_Channel_
« Last Edit: November 15, 2016, 07:52:22 pm by Sonny ReVerb »
« Reply #4 on: November 15, 2016, 09:32:05 pm »
You have that backwards. The 6G16 uses a linear pot.
« Reply #5 on: November 16, 2016, 05:25:53 am »
Sorry guys
I did not have time to dig into this
That's why I moved the post here
The guys here are more able to answer questions like this
I changed the single AB763 layout to a 0033, but like Steve said, that .001 difference does not matter
« Last Edit: November 16, 2016, 05:31:16 am by EL34 »
« Reply #6 on: November 16, 2016, 10:52:08 pm »
You are correct, sir. Thanks.
