August 29, 2026, 03:04:35 pm
Hoffman Amps Forum image Author Topic: Too Trebly Supro  (Read 4112 times)
Offline billcreller
  • 1934
Too Trebly Supro
« on: November 18, 2016, 09:36:54 am »
Back around 2007 I built a single-end type Supro.  Schematic Heaven calls it "Late'50s 1X 6V6 Amp"  It works good, but  it has a too treble tone for my taste.  I had added a cathode cap to the cathode resistor on the 6V6, and added one the 2nd half of the 12AX7, (2nd stage pre-amp ?)  Coupling caps are .047 in place of the spec .01 caps.  Very simple circuit, but not as simple as I am !
Any ideas about getting less treble from this ?
I'll see if I can show the schematic....
well, that didn't work ! :cussing:
« Last Edit: November 18, 2016, 09:42:32 am by billcreller »
Re: Too Trebly Supro
« Reply #1 on: November 18, 2016, 09:50:07 am »
A different speaker could be all you need.
« Reply #2 on: November 18, 2016, 03:41:49 pm »
> cathode cap ....the 2nd half of the 12AX7
10-20uFd? Or 0.68uFd?
0.68 gives the Marshall Scream. Not what you want.
Fender leaned to 10+uFd which gives full bass (equal to treble).
Offline billcreller
  • 1934
« Reply #3 on: November 18, 2016, 10:11:22 pm »
That cathode cap is a 20 mf.   I'll try smaller values.  The speaker is a 10 inch Weber. Chassis has
a speaker jack, so I can try some others..
Thanks !
« Reply #4 on: November 18, 2016, 10:39:40 pm »
Smaller cap value will have less bass.
« Reply #5 on: November 19, 2016, 08:36:29 pm »
Which can have the effect of "more treble".
