August 29, 2026, 03:03:06 pm
Hoffman Amps Forum image Author Topic: AA764 e-caps question  (Read 4076 times)
« on: November 21, 2016, 08:20:04 am »
I'm planning a Vibro Champ with a 1625 Power Tube (same as 807) with ~350V B+ for 10-11W of power
the PS will be with a FWB so, no 5Y3 tube there
the original amp uses a 3 node PS with 20uF 450V electrolytic caps
I have a few 47uF 450V e-caps under hands, do you think I can use it or they are too big ?
Sometime I've read that too big e-cap on PS can affect the tone response of the amp in a bad way, but I'm not a player .......
One other thing, as to tame the possible noise (at the end it is an SE amp not a PP) what do you think about to add a node to the PS ?
I mean one other 47uF e-cap and a ..... 220R (?) resistor
Re: AA764 e-caps question
« Reply #1 on: November 21, 2016, 08:43:32 am »
I would use them.
Absolutely. Consider changing the 220Ω resistor to a choke.
« Reply #2 on: November 21, 2016, 08:51:17 am »
Thanks Steve
« Reply #3 on: November 23, 2016, 01:07:55 pm »
K, here's my PSU I'm going with for my 5F2A SE Princeton.
I'm using a wired ground with insulated/isolated input/speaker jacks, like K. O'Connor/Merlin and heater DCV feeding a 100R/5w humdinger pot. Filter caps are Panasonic EE series radials, I like them a lot so far. I added the last 10uF B+ filter cap because of the wired ground and the DCV stand off. The NFB goes to the 2nd gain stage so the OT gets grounded there. A lot of current is there because of the OT ground and too many ground wires on 1 turret. Also I didn't want the DC stand off filter cap grounded with the OT. I might change the value of the last 2 @ 10K B+ dropping R's that feed the D/E B+ nodes. I've had it on my BB and it has worked well and is very quite.  :icon_biggrin:
I know your going with SS rectifier B+, I'm using GZ34, I don't like a 5Y3 so far.  :dontknow:
A little cleaner with the higher B+DCV.
« Last Edit: November 23, 2016, 02:26:41 pm by Willabe »
