September 18, 2026, 06:17:59 am
Hoffman Amps Forum image Author Topic: Is this transformer wrong for this purpose ?  (Read 6891 times)
« on: December 12, 2016, 02:32:24 am »
I'm planning an SE amp with 2 x 6SL7 + 1 x 6SJ7 + 1 x 1625 (@ 350V - plate 50mA - G2 5mA max)
at the first I was thinking to use this transformer (270V @ 80mA - 14V @ 2A)
http://www.musikding.de/Toroidal-transformer-230V-270V-14V
then I've think it will be better to use this transformer (250V @ 100mA - 6.3V @ 1.5A - 12.6V @ 1A)
https://www.tube-town.net/ttstore/Transformer/Power-Transformer/Toroidal/Toroidal-47VA::5391.html
But ..... but this morning I remembered a recent post from PRR
(this is an extract)
so, of those 100mA @ 250V I can obtain only 62mA @ 350V DC
and the other transformer (80mA @ 270V) obviously is less, 49mA @ 378V DC
Always when thinking to buy a transformer I look to the availability of current declared by the seller
but I think they declare the AC rating, not the DC rating
Must I use a bigger transformer like this ? (250V @ 120mA - 6.3V @ 3A - 12.6V @ 1A)
https://www.tube-town.net/ttstore/Transformer/Power-Transformer/Toroidal/Toroidal-62VA::5322.html
Re: Is this transformer wrong for this purpose ?
« Reply #1 on: December 12, 2016, 09:22:19 am »
... But ..... but this morning I remembered a recent post from PRR
... I think they declare the AC rating, not the DC rating
The "AC Rating" of current is directly related to the VA rating of the transformer.  However, most often transformers for tube amps do not specify the high voltage secondary in terms of that "AC Current".  Instead, they often provide a d.c. current rating of what can be drawn after rectification.
You can only verify one way or the other if you have the total VA rating of the transformer, along with the individual secondary ratings.
It would seem you can use any of the transformersa you mentioned (within constraints of heater voltage/current)
« Reply #2 on: December 12, 2016, 11:08:21 am »
Ciao HotBluePlates, Thanks
About this transformer, nothing is told about VA, only output voltages and currents
but those other transformers has a VA rating
This is rated 47VA
so
250 x 0.1 = 25 (VA or something like that)
6.3 x 1.5 = 9.45 (VA)
12.6 x 1 = 12.6 (VA)
25VA + 9.45VA + 12.6VA = 47.05VA (close to the spec of the seller)
the other is rated for 62VA
250 x 0.12 = 30 VA
6.3 x 3 = 18.9 VA
12.6 x 1 = 12.6 VA
30VA + 18.9VA + 12.6VA = 61.5VA
For the other transformer I think it is the same thing also if they didn't specify the VA rating
so I think I can only use the 62VA transformer (250V @ 120mA - 6.3V @ 3A - 12.6V @ 1A)
Am I wrong ? Can the 47VA transformer be used ?
« Reply #3 on: December 12, 2016, 11:49:29 am »
Your first post stated you only needed ~55mA (plus a few for the preamp).  You've got plenty of margin, even with Hammond's derating to 0.62 * Current.
« Reply #4 on: December 12, 2016, 02:13:39 pm »
Thanks HBP
so the 47VA seems to have enough juice
this is  the schematic (near definitive I hope)
I know the power tube presumed consumption, and I can think about few mA for the preamp tubes
but I've no idea about the consumption of the tube used as oscillator (??)
100 x 0.62 = 62
62 - 55 = 7mA
« Last Edit: December 12, 2016, 02:16:43 pm by kagliostro »
« Reply #5 on: December 12, 2016, 05:10:54 pm »
It's not that critical.  Go a few milliamps over and you might get a few volts less on that secondary, which will mean nothing compared to the overall B+ voltage.
« Reply #6 on: December 12, 2016, 05:30:44 pm »
Yes, that has sense also because the filament windings will not be used at max
Thanks again
« Reply #7 on: December 13, 2016, 06:11:26 am »
http://www.hammondmfg.com/pdf/EDB290CAX.pdf
This is the universal version of the 290AEX
Fender Powertransformer for Champ, Vibro Champ, Princeton, Princeton Reverb, Tweed Deluxe
Fender Part Number 125P1B and 022772
is correct to say that Hammond indicate the AC disposable current ?
« Last Edit: December 13, 2016, 07:17:29 am by kagliostro »
« Reply #8 on: December 13, 2016, 06:27:09 am »
Absolutely. Specifically says so right in the electrical data table.
« Reply #9 on: December 13, 2016, 07:23:40 am »
Thanks Steve
it was not so clare to me (that they refer to AC and not to DC)
« Last Edit: December 13, 2016, 07:29:48 am by kagliostro »
« Reply #10 on: December 13, 2016, 08:12:18 am »
"115mA rms" is the clue.
« Reply #11 on: December 13, 2016, 08:30:24 am »
rms .... OK
