September 17, 2026, 05:45:34 am
Hoffman Amps Forum image Author Topic: Photo of the Deluxe Reverb  (Read 5632 times)
Offline Planobilly
« on: December 19, 2016, 08:44:32 am »
Hi Guys,
This was my first attempt at  trying to make a case and covering it. I made a few mistakes and learned a good bit about the process. I think I learned enough to do a good job on the next one. Education is never cheep...lol
The amp is basically a Hoffman AB763 with a few mods. The current speakers are  two Celestion vintage G12M  from the 1980s. I ordered Weber D12 and also Weber NeoMag to experiment with. The NeoMag is Weber's take on a JBL D120F. They should be here is a week or two.
The reverb is still producing more noise when it is turned up than I am happy with. Other than that the amp only starts to produce a very small amount of hum/hiss when the volume is turned up past 90%. I am not sure just how to reduce the reverb noise.
Cheers,
Billy
EDIT: The plate is actually not black but a darker brown. I want to get set up to do engraving for face plates but I need a new computer and a high speed 12000 RPM motor for my CNC mill. Most likely around $1500 worth of stuff. May be a while before I can afford it. Never enough money...lol
« Last Edit: December 19, 2016, 08:50:02 am by Planobilly »
Between fishing, flying, and fooling around with guitar amps, somehow 70 years got behind me. Shorter of breath and one day closer to death as the song goes.
Re: Photo of the Deluxe Reverb
« Reply #1 on: December 19, 2016, 12:49:32 pm »
Looks great, what glue did you use for the tolex?
« Reply #2 on: December 19, 2016, 02:50:25 pm »
Nice build.
Offline Joel
« Reply #3 on: December 19, 2016, 03:27:35 pm »
You won't be disappointed with this amp.  My single channel build sounds amazing.  I'm positive yours does too.
I like how stuff from the 80's is now seen as "vintage".
The mouth of a happy man is filled with beer  - Egyptian Proverb
« Reply #4 on: December 19, 2016, 06:10:11 pm »
Very nice job on the amp!  It looks great.  Thanks for sharing the photo.
Best regards,  Jeff
Offline Planobilly
« Reply #5 on: December 19, 2016, 07:30:28 pm »
Thanks guys
I used 3m spray glue. I would use a stronger glue on the next build.
Cheers,
Billy
« Reply #6 on: December 20, 2016, 02:53:14 am »
Hey Billy, Yeah, used that spray stuff and...............
I use gel bond as it is less stringy than normal contact, less messy.
The trick I find is to apply the contact and leave it for at least 5 minutes before putting the tolex on.
I paint only to start of the radii on the edges.
Once I have wrapped the tolex around the four sides I do all the edges.
By doing this the contact softens the tolex enough to make it pliable and a little stretchy, makes the tolex stick to those square corners.
Offline markmalin
  • Malin Sweet Loraine
    • Malin Amplification
« Reply #7 on: December 20, 2016, 11:39:39 am »
Nice work!
"... there are Flying V's and then there are the ones shaped like peanuts..."  - my son at age 9
Offline Planobilly
« Reply #8 on: December 20, 2016, 04:57:12 pm »
Hi Timbo,
Nice looking cabinet.
Covering cabinets is like anything else....it takes a certain amount of skill that takes time to develop. I learned enough on this first attempt to know how to prevent most of the issues I encountered on the next one.
Cheers,
Billy
« Reply #9 on: December 21, 2016, 12:30:44 am »
Great :thumbsup:
