September 16, 2026, 02:01:24 am
Hoffman Amps Forum image Author Topic: Let there be light  (Read 6021 times)
Offline p2pAmps
    • p2pAmps
Let there be light
« on: January 14, 2017, 08:26:51 pm »
I just installed some LED lights above my work bench and OMG, sooooo much better.  Tell me why I waited so long to do this.  If you don't have this don't hesitate like I did...
« Last Edit: January 14, 2017, 08:29:00 pm by p2pAmps »
Everything Affects Everything
Re: Let there be light
« Reply #1 on: January 14, 2017, 08:55:01 pm »
I could sure use that!
« Reply #2 on: January 15, 2017, 04:41:26 am »
Got my first LED trouble/work light last year. What a difference over the old 100W bulb!
Offline p2pAmps
    • p2pAmps
« Reply #3 on: January 15, 2017, 05:39:52 am »
I grabbed some 1" square tubing, welded up an easy frame and mounted it to the back wall.  Then attached the track lighting (Lowes) all for under 200 bucks.  If you need this go for it, its so worth it.
« Reply #4 on: January 15, 2017, 09:59:20 am »
its so worth it.
My old co-worker friend designs n builds LED lighting for the "medical" crowd here, I have 2 proto-types, both are 100watt LED chips - DO NOT look at the light :icon_biggrin:
His 500watt-ers will blind you for days!
Offline alerich
  • This one goes to 11.
« Reply #5 on: February 16, 2017, 12:02:40 pm »
They actually make LED bulbs that are physical drop in replacements for florescent bulbs. The light housing needs rewired - ballasts no longer required so it can be removed. They just replaced all of the florescent bulbs with LED style where I work and man, what a difference. I did not realize just how badly some of the old bulbs had aged. You need SPF 35 in there now. Draws less current and looks like brand new every day.
