September 16, 2026, 06:05:57 am
Hoffman Amps Forum image Author Topic: choke spec question  (Read 4513 times)
Offline 12AX7
choke spec question
« on: January 17, 2017, 01:20:10 pm »
Any reason i can't use a 100mA/20H choke with a 18 watt PT? I tried it and i really like what it does for the amp but before i make it permanent i want to be sure.
Re: choke spec question
« Reply #1 on: January 17, 2017, 02:58:57 pm »
I assume the choke is between the plate and screen filter nodes on the B+ rail.  It's got lots more current handling than needed but that's okay.  20H is Marshal territory and fine if you like the tonal performance.
Offline 12AX7
« Reply #2 on: January 17, 2017, 03:23:06 pm »
Yes, thats the location and yes, it's a marshall flavored amp. Thanks 4 the reply....bolting it in...
