September 17, 2026, 07:38:54 am
Hoffman Amps Forum image Author Topic: Resistor in parallel and Power - Question  (Read 7142 times)
« on: February 01, 2017, 02:49:39 pm »
Today I was to the local electronic shop looking for a (round and relatively small) 300R 10W resistor
They have not so much components and had only a 330R ceramic resistor that I got also if it is a bit too long for my board
I got it also if it is 330R (waiting for a correct one) and I've think to put a 3.3k 2W resistor in parallel to have 300R as result
After that I remembered that may be I've some 10W 3.3k resistor that are of the correct lenght and if I put a 330R 2W resistor
I'll obtain the desired 300R
But I've a doubt, if I use a 10W 330R + a 3.3K 2W resistor the larger current follows the lower resistance path, so no dissipation problems
and if I use a 3.3K 10W + a 330R 2W resistor what will happen ? Is this an easy way to burn the 330R 2W resistor ??
Many Thanks
« Last Edit: February 01, 2017, 03:17:55 pm by kagliostro »
Re: Resistor in parallel and Power - Question
« Reply #1 on: February 01, 2017, 03:27:22 pm »
possible to leak much smoke.
can you get three 1K 5W? that with 3.3K 1W or 2W would work.
« Reply #2 on: February 01, 2017, 03:41:16 pm »
Thanks DummyLoad
I must give a look to my stock to see what I've or use the 10W 330R + a 2W 3300R
this way I think I've no problem
« Reply #3 on: February 01, 2017, 03:59:02 pm »
What is the purpose of the resistor. 300Ω may not be such a critical value. Perhaps any value between 200 and 400 will be acceptable?
« Reply #4 on: February 01, 2017, 04:04:07 pm »
Ciao Steve
the resistor is for the cathode of the 1625 on the schematic you have seen (modified AA764 + 5C1)
« Reply #5 on: February 01, 2017, 04:49:37 pm »
In that case I definitely would not zero in on 300 as the magic number.
« Reply #6 on: February 01, 2017, 05:32:19 pm »
Grazie Steve
       May be I must think to a more flexible solution ..... :rolleyes: :rolleyes: :rolleyes:
« Reply #7 on: February 01, 2017, 06:23:04 pm »
... if I use a 10W 330R + a 3.3K 2W resistor the larger current follows the lower resistance path, so no dissipation problems
and if I use a 3.3K 10W + a 330R 2W resistor what will happen ? Is this an easy way to burn the 330R 2W resistor ?? ...
Let's solve the problem and find out.
How much voltage do you expect across the resistors?  Pulling a number out of the air, I'll guess 15v.
Resistors in parallel see the same voltage.
15v / 3.3kΩ = 4.5mA
15v * 4.5mA = 68mW
15v / 330Ω = 45.5mA
15v * 45.5mA = 0.68W
Do you expect more than 50mA of idle current (plate & screen)?  If no, it looks like 2w is plenty for either resistor and 10w is overkill (but might be cooler for a nearby cap).
Ofcourse you could have calculated as 15v2 / Resistance, and found power directly.  But knowing the implied current might be helpful in some cases.
« Reply #8 on: February 01, 2017, 09:59:09 pm »
was wondering the same thing... usually we double up on wattage or even 3X if there's big swing in current demand.
« Reply #9 on: February 02, 2017, 09:19:48 am »
Many Thanks Bill & Pete
I think there will be ~18V across the resistor(s), it is the cathode resistor of a 1625 tube in an SE amp
here schematic
(There is a typo, bass cap is .1 NOT .01)
and ... yes, 10W was planned as to be a safe situation, in an SE amp I don't think there will be a large swing in current demand
I've this nice (and smaller 3.3K resistors that fits better the board)
respect to the 330R ceramic resistor I got yesterday
But when Steve told
I started wondering a different solution (more flexible)
a 220R 10W resistor + this russian 220R ceramic pot and this give me a range from 220R till 440R to perfectly tailor the bias
but I'm still wondering about what to do (there are also other solutions, one is to find a lot of correct sized resistor in various values  :icon_biggrin: )
Many ideas but well confused  :laugh: :laugh:
« Last Edit: February 04, 2017, 07:22:35 am by kagliostro »
« Reply #10 on: February 02, 2017, 09:05:03 pm »
But when Steve told
You probably won't know the "ideal resistance" until you actually build the amp.  You could use the wirewound pot, but I suspect once you get it close to a happy value of resistance, you probably won't change it much ever again.  In that case, it seems a waste to use the pot.  But if you already have the pot, then cost doesn't really matter unless you have some other project where it would be critical to have.
« Reply #11 on: February 02, 2017, 10:54:21 pm »
that's nothing more than a 807 SE.
https://frank.pocnet.net/sheets/155/8/807.pdf
probably going to have around 14 to 15V Vk. to keep Pdiss around 22.5W @ 335V, you'll need about 75mA Ik. so 14V-15V/75mA ~~180 to 200 ohms.
« Reply #12 on: February 04, 2017, 02:46:39 am »
Thanks Pete
I've this extract of the 807 datasheet
Seems that (with 350V B+) plate + screens are around 59mA
I don't know the exact value of  Rk (I think they refer to a fixed bias with that  -18V)
but seems that also a less W rated resistor can be used (may be 7W)
I'll prefer to use a bigger one but I'll see what I can find
« Reply #13 on: February 04, 2017, 03:34:38 am »
if V bias fixed is shown to be at -18V with 350V, a good approximation is that you need 18ish Volts on the cathodes with auto bias. so 18V/58mA ~~310R. use a 330R. Va-k is actually 350 - 18V = 332V but still close enough to 350V to make the approximation valid. more or less. you're cutting hairs where you don't need to. fire it up with a 330R, measure Vk and make the determination if Pdiss is where you want it. in the spec sheet it's about 20W. on a footnote, during the initial power up, monitor your screen V closely; the closer to 250V it actually is, the closer the approximation is.
Offline ac427v
« Reply #14 on: February 04, 2017, 07:00:16 am »
Unrelated detail. Bass cap in the tonestack is .01?
--Craig
« Reply #15 on: February 04, 2017, 07:21:21 am »
Thanks Pete
Those are important info for me, I'm not very skilled and all this info give me help
Many Thanks Craig
is a typo, correct value is .1
Grazie
