September 17, 2026, 03:21:44 am
Hoffman Amps Forum image Author Topic: Presence circuit  (Read 4617 times)
Offline 12AX7
Presence circuit
« on: February 04, 2017, 09:10:21 am »
In your opinion, in marshal style circuits what is the tonal impact of the difference between a 4.7k ground reference pus a 25k presence pot verses using a 5k pot for the presence and eliminating the 4.7 resistor? I've had both but i am unsure of what the tonal impact is but i think there is one. The way i see it the 4.7k resistor is just a way to use a 25k pot and effectively make it work like a 5k put since it's in parallel, probably because marhall had a lot of 25k pots at the time or they  got them cheaper than 5k's. But i really think there may be some sort of difference totally, i just can't put my finger on it. But when i changed from the 25k pot and 4.7 resistor to the 5k pot alone it seemed to sound different somehow. Was it just placebo effect or do you think theres a difference?
Re: Presence circuit
« Reply #1 on: February 04, 2017, 11:14:01 am »
The 25K pot circuit eliminates the dc on the pot and the resulting scratchy sound when you rotate the pot.
Offline 12AX7
« Reply #2 on: February 04, 2017, 12:54:59 pm »
I know, I was just asking about tonal differences if any. Like i said, i seemed to have noticed something.
« Reply #3 on: February 04, 2017, 11:51:55 pm »
... But i really think there may be some sort of difference totally, i just can't put my finger on it. ...
If you can't be sure there was a difference, there probably was no difference.
