September 16, 2026, 02:01:36 am
Hoffman Amps Forum image Author Topic: blackface Fender Pro reverb AA165 tremelo ticking  (Read 6130 times)
Offline Bangy
  • Tube amp guy
« on: February 08, 2017, 08:56:56 pm »
My 67 BF Pro reverb has a ticking that follows the speed set, however nothing else effects it except disengaging the via the footswitch. Once disengaged its silent. Back on, If I turn the speed dial up the clicking increases tempo with the trem speed.
Intensity on 10 or 1 - same level of ticking
Volume off or on any volume no change in volume of the ticking.
2 prong AC. I have done nothing as the circuit is 100% original.
Roach gone bad? I think DOUG sells them, right? Im looking. . .
anybody?
Bangy
« Last Edit: February 08, 2017, 09:19:13 pm by Bangy »
Re: blackface Fender Pro reverb AA165 tremelo ticking
« Reply #1 on: February 08, 2017, 10:06:41 pm »
Probably not the roach. Maybe lead dress. Maybe circuit board is conductive around the roach. Try this...
Offline Bangy
  • Tube amp guy
« Reply #2 on: February 08, 2017, 10:44:16 pm »
HUm. . . But its worked fine for 52 years. Seems odd but Ill do some testing in the am. . . Thanks Sluckey
BAngy
« Reply #3 on: February 08, 2017, 11:10:11 pm »
Change that 2 prong AC cord to a 3 prong before you get stung.  :w2:
« Reply #4 on: February 08, 2017, 11:56:37 pm »
And if a 0.01UF snubber don't work enough, 0.02uF will probably be enough to slug it.
Offline Bangy
  • Tube amp guy
« Reply #5 on: February 09, 2017, 06:53:19 pm »
Thanks all. It seems in 68 or so Leo or whomever was CBS's guy at the time sent out a service bulletin which said this is a common occurrence and the fix is exactly what Mr. Sluckey (Why do I ever question the man???) posted.  @Willabee Ive been stung a few times (not with this amp) however, this one will never see a three prong its a looker not a player, like a time capsule BF. I am offloading a few of my finer ones.  So these type of buyers want everything original.
Anywho. . . When I took pics of the amp I was through a brown box, and a diff outlet, the problem came through my variac. I havent had a chance to recreate the before issue scenario (dif AC outlet and brown box)--but I will.
I was told by a super smart Fender tech this am that this is a well-known and frequent occurrence on BF Fenders, and is dependent more on the AC than anything.  I sold my last brownbox so I cant totally recreate the before until my new order is filled.
Thanks for chiming in everyone. . . BAngy
Offline robrob
« Reply #6 on: February 09, 2017, 10:43:00 pm »
RobRobinette.com
