September 13, 2026, 09:30:25 pm
Hoffman Amps Forum image Author Topic: Tweed Princeton 5F2A clone  (Read 7598 times)
Offline Joel
« on: March 22, 2017, 09:19:04 pm »
Just thought I'd share some pics of my recently finished Tweed Princeton 5F2A clone.
I wound both transformers.  And everything turned out very nicely.  Beautiful clean tone.
Edit:  +1 point if you can find the wiring error I made.  I took the pic before first power up...
« Last Edit: March 22, 2017, 10:16:38 pm by Joel »
The mouth of a happy man is filled with beer  - Egyptian Proverb
Re: Tweed Princeton 5F2A clone
« Reply #1 on: March 23, 2017, 08:24:03 am »
Hey man, that looks great!....love the wood look  :thumbsup:
REALLY COOL that you wound your own transformers!
While looking for your mistake, I noticed this potential foul:
Makes me more than a little nervous to have those high voltage wires coming through an uninsulated hole in the chassis....not a deal breaker but worth noting.
Offline mwelch55
« Reply #2 on: March 23, 2017, 01:44:39 pm »
Speaker not hooked up?
Nice looking build.
Offline timbertoes
« Reply #3 on: March 23, 2017, 02:33:59 pm »
Very nice :)
« Reply #4 on: March 23, 2017, 02:52:34 pm »
.....not to mention the power switch wiring
Is that wired how it looks?
Hope you didn't plug it in to find out that was wrong. :huh:
Offline Joel
« Reply #5 on: March 23, 2017, 04:20:18 pm »
Congrats Mr Silvergun!
When I double checked the wiring before first power up, the power switch was obviously wrong.  I cannot for the life of me remember what I was thinking when I first soldered it.  A thorough wiring check should be conducted before powering up for the first time!!!  Luckily, even if I had tried to power up it would have been OK.  The active would have been switched in whilst the neutral would have been switched out.  So, I had it wired OFF-OFF so to speak.
The cab is pine.  A couple coats of "golden teak" stain, followed by a couple coats of a tung oil + wax finish.  Buffed up to a nice glowing satin finish.
« Reply #6 on: March 23, 2017, 08:42:46 pm »
It is a deal breaker.  :w2:
You really should put rubber grommets in those holes.
Offline Joel
« Reply #7 on: March 24, 2017, 01:54:37 am »
I haven't used grommets for most of my amps.  The hole is deburred and smooth, which removes the cutting action any vibration may induce.
« Reply #8 on: March 24, 2017, 11:59:34 am »
I haven't used grommets for most of my amps.  The hole is deburred and smooth...
Add the grommets.  You may never need them, and it might take decades for the chassis to abrade the wire insulation.  But the original Fender amps (and pretty much every other brand) put grommets on holes like that to keep from inviting Murphy to the party.
I've never had a car accident, but I put on my seatbelt.  I also know someone who is not in the habit of wearing a seatbelt, even though they did have a car accident that sent them through the windshield...
Offline Joel
« Reply #9 on: July 22, 2017, 04:42:27 am »
This should make you happy Mr. HotBluePlates.  I added some hole grommets today as you suggested.  What a pain in the rear!  I won't be retrofitting like this again any time soon.
