September 16, 2026, 03:56:39 am
Hoffman Amps Forum image Author Topic: signal generators  (Read 8183 times)
Offline Tone Junkie
signal generators
« on: March 28, 2017, 08:42:36 pm »
Well I had 2 older ones I pickup at yard sales thought I could fix and use them . I think they just sat to many years. So now I have that brand new o scope and no signal generator any suggestions . Thanks in advance.
Bill
Offline pompeiisneaks
  • Tube is as Tube does
    • Daviszone
Re: signal generators
« Reply #1 on: March 28, 2017, 08:53:43 pm »
For guitar amp work, if you've got a smart phone, just download a function generator app.  It doesn't do tons, but it's enough to get a mini to 1/4" adapter on a cable and plug it in and adjust the phone volume on a sine wave to see how much the input is and how each stage is magnifying it etc.
I've used my phone for some time.
~Phil
Phil Davis
tUber Nerd =|D
« Reply #2 on: March 29, 2017, 04:45:35 am »
This is handy
http://onlinetonegenerator.com
Still i find a dedicated unit better. Voltage control is nice. I usually use less than 1 volt, actually 180ma and sometimes even less. It gives me a better idea of how touch sensitive the amp is. The lowest output pup i have measured is 93ma which was an old strat neck pup.
« Reply #3 on: March 29, 2017, 08:16:59 am »
+1 for software, although keep your eye open for "that great hardware" version.
I use this one;
https://secure.shareit.com/shareit/product.html?productid=300154061&languageid=1-1000
my note pad sound card does good until you get <~80hz, then you have to tweak back up to keep signal constant.
Offline BetterOffShred
  • I play tube amps..
« Reply #4 on: March 29, 2017, 11:38:45 am »
I have been thinking about getting one of these just for funsies...
http://www.ebay.com/itm/131932524140?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
-Brett
« Reply #5 on: March 29, 2017, 11:45:54 am »
That is cute!
« Reply #6 on: March 29, 2017, 12:08:06 pm »
Haha! I know right?  I know a lot of DIY pedal builders use them quite a bit for troubleshooting etc, seemed like it would work for a guitar amp too!  I've just been looping something into my old DD-3 and then playing that into the input for a signal for my amp/pedal troubleshooting.
-Brett
    • Daviszone
« Reply #7 on: March 29, 2017, 12:45:03 pm »
That seems it would definitely work, nice!
~Phil
Phil Davis
tUber Nerd =|D
« Reply #8 on: March 29, 2017, 04:51:29 pm »
-Brett
you could install that in a $20 Bud/Hammond enclosure. a rotary switch does away with the jumper block, mount the pots on enclosure front panel extending them to the PCB with wires, do the same with the output jacks and power jack.
« Reply #9 on: March 29, 2017, 07:01:43 pm »
-Brett
Yeah man. I ordered a $4 lm317 voltage regulator setup and did that.  It's pedal power on demand up to 20V. Love it.
-Brett
Offline NO_H2O
« Reply #10 on: April 02, 2017, 10:43:10 am »
I ordered one of the XR2206's it arrived and I plan to build it while I am recovering at home.
« Reply #11 on: April 02, 2017, 10:02:11 pm »
Great!  Let us know how it goes, and I hope your recovery is fast and full of amp building!
-Brett
