September 15, 2026, 04:18:50 am
Hoffman Amps Forum image Author Topic: Stout TMB question  (Read 7202 times)
Offline bjsweek
Stout TMB question
« on: April 04, 2017, 01:09:45 am »
I am about to start building a Stout 18 TMB; would there be any issues using a fender style, 6.3v pilot instead of the neon line voltage? ..and any other suggestions or tips prior to starting this endeavor?
Re: Stout TMB question
« Reply #1 on: April 04, 2017, 01:35:34 am »
No issues if you will be using a blank chassis. Just make the necessary wiring changes to the lamp holder.
If you use Hoffman's pre-drilled chassis be sure there's enough room on the front panel. You'll have to make the hole bigger. And you may need to move the cap can to provide clearance. More info on this page...  http://el34world.com/Forum/index.php?topic=18606.0
Offline purpletele
    • Vallis Enterprises, Inc.
« Reply #2 on: April 04, 2017, 02:29:43 am »
Here is a gut shot of my 18 Watt Stout.
I re-purposed a Blackheart 5 for the project.  I haven't worked with that chassis, so I am not sure of the alternate cap locations.
I do like the using the Fender style light as well.
Check out the recent threads on the Blackheart conversion.  Sluckey and Tubenit had some great Mods that really made my amp sing.  Fantastic amp!
Update:
I see from the thread listed by Sluckey above, and I see the photo of the cap mounted next to the transformer, that is similar to what I did,  I highly recommend purchasing a 1 1/2" punch or borrowing one, unless you can find a Step Bit that goes to 1 1/2 ".
BV
« Last Edit: April 04, 2017, 02:37:52 am by purpletele »
Offline bjsweek
« Reply #3 on: April 04, 2017, 12:14:49 pm »
Thanks, I am designing into a completely new combo design. Another question: 2x10s or 1x12?
I will post photos of my last build, a stripped down AC30 roughly based on Doug's schematic.
Offline purpletele
« Reply #4 on: April 04, 2017, 02:02:58 pm »
I have never played a 2 x 10 combo, but I have carried them.
I am into lightweight cabinets so I opt for 1 x 12's
Offline bjsweek
« Reply #5 on: April 04, 2017, 06:28:21 pm »
what are these "mods" of which you speak? I am interested!
Offline purpletele
« Reply #6 on: April 04, 2017, 07:40:46 pm »
I'll send a link to the details.  One or two voicing tricks that they boys passed along as well as the layout for the PPIMV should you choose to implement it.
I highly recommend the changes, but I would not install them until you know for sure you want to alter the voicing.
I spent a few weeks with the amp and tried a few different tubes, etc.  and then made each change one at a time.
It was a good experience for me.
Look for details later
Offline bjsweek
« Reply #7 on: April 05, 2017, 12:26:55 am »
some more photos:
Offline purpletele
« Reply #8 on: April 05, 2017, 12:57:25 am »
^^^Cool Amp and cabinet!
Offline purpletele
« Reply #9 on: April 05, 2017, 01:01:46 am »
Offline bjsweek
« Reply #10 on: April 08, 2017, 01:37:52 pm »
As i am looking through the schematic here i notice there is no "stand by", as i will use the 5Y3 tube rectifier instead of a solid state replacement; i was planning on running a stand by circuit. Thoughts?
Offline bjsweek
« Reply #11 on: April 08, 2017, 01:57:29 pm »
Also, Does anyone know where i can get bell covers to fit this stout OT?
Offline purpletele
« Reply #12 on: April 08, 2017, 02:04:18 pm »
I did on mine
