September 15, 2026, 05:48:17 pm
Hoffman Amps Forum image Author Topic: anyone built a 6G6-B  (Read 6307 times)
Offline Tone Junkie
« on: August 31, 2017, 09:36:47 pm »
Looking at schematics thought this was a different tone stack arrangement. wondered if there was if there was any sonic bliss to be had.
Bill
Re: anyone built a 6G6-B
« Reply #1 on: August 31, 2017, 09:48:52 pm »
Think Brian Setzer, then Google it and then wait for Ed C to catch on.
You cant say 6G6B without waking him up. Give him some time, things are a little slower down south.
Cool amp...I'd have to try it with the channels jumpered
« Reply #2 on: August 31, 2017, 10:18:08 pm »
http://el34world.com/charts/Schematics/files/fender/Fender_BASSMAN_6G6B.pdf
There's two channels and two tonestacks. Both are based on the classic Fender BMT. Bass channel has a way-small fixed Mid resistor, oversize caps, and fixed treble resistors, then a separate Treb knob at a later point. Norm is routine except the Treb pot is extended to severe top-cut.
« Reply #3 on: September 01, 2017, 06:37:58 am »
The 6G6b 'bass' channel is an awesome blues lead channel
« Reply #4 on: September 01, 2017, 08:46:28 am »
I take it back...
I forgot about the cathode follower on the bass channel that would put the 2 signals out of phase if jumpered, so no jumpering for me.
Offline plumcrazyfx
« Reply #5 on: September 02, 2017, 07:56:27 pm »
This is also Harrison's main amp from about 65 on and a favorite of Tom Petty.  I'm lucky to have an original as well as a 6G6 - I plan on making a couple clones - great amps.  The 6G6-A is the one I'm interested in now - the plate voltage runs significantly higher than the other 2.
« Reply #6 on: September 13, 2017, 04:55:40 am »
You need to change one tube to  jumper. A pentode is nice and keeps the phase correct. Then channel 1 is you drive.
« Reply #7 on: September 13, 2017, 05:03:51 am »
Bill
The second channel has the 350k taped pot. It works from top center. Right adds and left reduced. It is plate driven and does not steal a lot of gain. Channel 1 has a different setup and is not as responsive, but does have a tube tone. Needs a couple of tweaks.
Great amp. Been my go to for a long time now. What is cool is it always has some bite ready when you dig hard, but lighten the touch and clean. I call them full bodied. Tone and not weak anywhere.
