September 08, 2026, 09:07:44 pm
Hoffman Amps Forum image Author Topic: Tube Find  (Read 16987 times)
Offline silverfox
Tube Find
« on: October 21, 2017, 04:47:25 pm »
Found a box of tubes at an estate sale. As I was leaving my wife says, did you see the tubes? Yeah. Under the work bench? Oh! Back inside the garage found the second box. All appear to be as represented on the box; even some of the older number tubes, 80, for example. Not sure what I'm going to do but I'll keep some around so I could build a short wave- If I had to.
silverfox.
« Last Edit: October 21, 2017, 04:50:23 pm by silverfox »
Re: Tube Find
« Reply #1 on: October 21, 2017, 08:15:40 pm »
nice score, now you can sort :laugh:
Re: Tube Find
« Reply #2 on: October 22, 2017, 03:32:15 am »
those 6F6-G would make a killer little 10-11W amp with 300-325V to the plates in fixed or auto bias. use a 10K Ra-a load such as the hammond 1609A or the edcor GXPP-10K.
Offline silverfox
Re: Tube Find
« Reply #3 on: October 22, 2017, 12:01:57 pm »
DummyLoad:   those 6F6-G would make a killer little 10-11W amp
Were they used in a commercial build? I'm thinking my friend from the late 60's had a Gibson that may have used them.
silverfox.
Re: Tube Find
« Reply #4 on: October 22, 2017, 02:10:44 pm »
no clue about anyone that used them.
worked this up - should work well but may need tweaking - a poor man's supro. i call it: El Gringo
Re: Tube Find
« Reply #5 on: October 22, 2017, 02:12:40 pm »
conditions i used for the design - see attached.
