September 15, 2026, 01:25:20 pm
Hoffman Amps Forum image Author Topic: ESR Meter - Someone has experience with cheap ones ?  (Read 11837 times)
« on: January 03, 2018, 05:11:02 am »
Is a lot of time I would like to buy an ESR meter but a good one will cost something like 115 € + VAT ........
https://it.rs-online.com/web/p/tester-lcr/6858791/
on e-bay is possible to find some units (that are declared as able to measure also ESS) that are really cheap (start from ~20-25€ and less in KIT)
https://www.ebay.it/itm/B1-Color-1-8-TFT-ESR-Meter-Transistor-Resistor-Diode-Triode-Capacitor-Tester-ZD/302509369288?hash=item466ef6a7c8:g:2KYAAOSw9gRZ-Upb
Someone has experience with low cost ESR meters ?
« Last Edit: January 03, 2018, 05:16:13 am by kagliostro »
Offline bnwitt
  • Crankin' out the tone.
Re: ESR Meter - Someone has experience with cheap ones ?
« Reply #1 on: January 03, 2018, 09:46:21 am »
Franco,
I purchased the fully assembled Anatek Instruments Blue ESR meter for under $100 and it works great.
https://www.dropbox.com/sh/kza6ndrxvvo0c1o/AAAsG45HzSOB3Q8ZPW3UdXaHa?dl=0
Barry
« Reply #3 on: January 04, 2018, 07:34:26 am »
Many thanks Friends
the ESR meter is not very diffused as DIY laboratory equipment, but sometime friends give me old apparatus to dismant and to put on the garbage some very nice e-cap that at the capacitor meter seems in good shape, only because you aren't sure 100% about it is a pain
I really think I'll get one soon
Offline Refugee
« Reply #4 on: March 03, 2018, 07:12:58 pm »
Those testers are good and cheap too.
I bought mine from banggood on the web.
It can even test IR remote controls displaying the ID code and the key code as two pulse trains.
« Reply #6 on: March 03, 2018, 08:08:07 pm »
Can you test "in circuit"?  (powered off)
Offline Refugee
« Reply #7 on: March 04, 2018, 08:06:18 pm »
You would need to look at the circuit diagram to see what is connected to the part you are measuring and make adjustments to the readings you get.
In some circuits it will not work at all.
Offline byoungblood
« Reply #9 on: August 26, 2018, 08:56:09 am »
I use the DER-5000 LCR meter for sorting resistors, checking out caps, and identifying unknown inductors. I paid about $90 off of eBay from a Japanese seller, so just be patient when it comes to shipping. Because of its intended use, it has no input protection, so it is best to avoid in circuit testing or be doubly sure that all caps in the equipment are discharged.
Offline Refugee
« Reply #10 on: October 13, 2018, 09:35:03 pm »
The one in the video is like mine but without the sensor for testing remote controls.
I just plug it into a USB port for a couple of hours every couple of months to charge the internal up again.
