September 15, 2026, 10:16:17 pm
Hoffman Amps Forum image Author Topic: Blues Jr Conversion Line Out  (Read 5556 times)
Offline HARodgers
« on: February 10, 2018, 11:57:01 am »
Hi,
I was just wondering if it was possible to use the second output jack on the blues junior conversion as a line out (to record into a USB audio interface) and if so, what resistor values I would need for this and which lugs I would connect the resistors to?
Also, is it possible to swap the "Meat" control for a presence control, and if so, how would I go about doing this?
Cheers in advance for any help
(Sorry if I've posted this is in the wrong place!)
Offline 2deaf
  • Now too deaf for 100 watts
Re: Blues Jr Conversion Line Out
« Reply #1 on: February 10, 2018, 06:31:28 pm »
It sounds like you have two speaker jacks.  If so, attached is a typical line out arrangement.
The meat control can easily be converted to a presence control as attached.
Offline HARodgers
« Reply #2 on: February 13, 2018, 05:11:19 pm »
That is absolutely perfect - thankyou!
Would i need any extra resistors to replace the variable that would have been the meat control, or could I use a trimpot to have an internal meat control?
Offline 2deaf
« Reply #3 on: February 13, 2018, 10:29:09 pm »
The meat control is gone because we swapped it for a presence control.
