September 08, 2026, 06:44:00 pm
Hoffman Amps Forum image Author Topic: Princeton in a Champ  (Read 39188 times)
Offline purpletele
    • Vallis Enterprises, Inc.
« on: February 16, 2018, 05:40:19 pm »
I was inspired to build a very nice amp in a Champ cabinet.  I have a colleague that is running three Champs, and I recently spent a weekend tweaking a Super Champ X2.
I was not impressed at all with the amp, so I decided to surprised my colleague with a Princeton Reverb in a Champ.
I put together a basic layout or block diagram, it seemed to work fine so I ordered two chassis' from Synaptic Amplification on Reverb.  So far I am really liking the chassis style and material.
Barry was kind enough to assist me on a faceplate drawing.  Everything seems to fit just fine.
Funny dimension on the chassis taken from Mojotone specs.  1/6th  ?  I think my chassis is 6 1/8th, that is strange to post and make something in that dimension.
I think this will be another cool Fender project.
Re: Princeton in a Champ
« Reply #1 on: February 16, 2018, 06:18:59 pm »
It will be interesting to see how this turns out..  that is alot of stuff to cram into a Champ chassis.. but it looks doable.
Offline purpletele
« Reply #2 on: February 16, 2018, 07:17:57 pm »
I can easily utilize a stand up transformer if needed but I think it works, we'll see next week, I have some iron arriving.
« Reply #3 on: February 17, 2018, 09:43:29 am »
A Champ sized Princeton or even Princeton Reverb is intriguing to me. Lots of players these days have mentioned having something around 15 watts, small, light an portable for small gigs. This would fit that description nicely. With a stand up PT there would be plently of room inside but I wonder about clearing a 10" speaker in a small champ cabinet. I think it might.
Offline purpletele
« Reply #4 on: February 19, 2018, 09:27:49 pm »
Princeton Champ Update
I received a TP25 Transformer today so I made a template and moved a little closer to a layout.
My current layout works but it doestn't leave much room for Connection strips and such.
Any warnings or encouragement?
I think I can make it work.
Offline purpletele
« Reply #5 on: February 19, 2018, 11:35:45 pm »
I don't think I have enough room with the TP25.  I'll use that for a standard Princeton Chassis
TP25:  Upgrade Power Transformer for BF/SF Champ™, VibroChamp™, Bronco™, and Princeton™. 310V-0-310V @ 150ma, 6.3V at 4.5A, 5V at 2A. 50V bias tap, center-tapped heater winding and internal hum shield brought out to a lead for grounding.
MOJO 760: 330-0-330 V @ 75 mA
Thinking about using this Edcor Stand Up
Edcor XPWR061 Stand Up.
Power transformer for a 120V, 60Hz. line to 600V (300-0-300) at 120mA center tapped, 6.3V (3.15-0-3.15) at 3A center tapped and 5V at 2A.
This looks like a good alternative transformer.
Please let me know if I am not seeing something.
BV
« Last Edit: February 20, 2018, 12:49:14 am by DummyLoad »
« Reply #7 on: February 20, 2018, 12:36:17 am »
suggestions: lose the valve rectifier & use a choke. consider a JJ 40-20-20-20 can cap.
Offline purpletele
« Reply #8 on: February 20, 2018, 01:20:55 am »
Pete,
That is beautiful, I like the 18085, thank you!
I was wondering about the SS rectifier as well as a choke.  I bet that stiffens it up and really drives a 10" speaker.
I am building the HPR so I have the JJ Cap Can on hand.
I am going to build a standard HPR in a Mojo Chassis and use the TP25.  That will be a good way to get to know the circuit before I stuff it into a little container.
Thank you
BV
Offline MFowler
« Reply #9 on: February 20, 2018, 06:50:45 am »
Great project and there is plenty of room in a Champ chassis.
I built a JCM800 2204 50w circuit into a Champ.
I used a custom Champ size aluminum chassis, Trainwreck Pacific transformers and recycled Ceriatone broken Express faceplate.
Mark
Offline purpletele
« Reply #10 on: February 20, 2018, 08:27:17 pm »
Mark
I bet that amp want to launch into orbit.
Offline MFowler
« Reply #11 on: February 21, 2018, 08:02:57 am »
Yeah it rocks!
Offline davidwpack
    • My music on reverbnation
« Reply #12 on: February 21, 2018, 08:37:24 am »
Hey, that's really nice looking!  I wish Doug would get some of that red circuit board material...or blue.
« Reply #13 on: February 23, 2018, 06:40:54 am »
inductive parts are for a 40W vibroverb - 5881 or 6L6GB or 6L6GC. see notes on drawing. i show 4" chassis straps. champ uses 3" if you use the princeton LTPI you shave 1/2-3/4 of board length. bias pot is type RV6. board mounted on 3/4 standoffs. relocate bias put on chassis and use type RV4 or similar.
« Reply #14 on: February 23, 2018, 02:41:05 pm »
... My current layout works but it doestn't leave much room for Connection strips and such.
Any warnings ...?  ...
I only glanced at Pete's layout file.  Whichever one you use, triple-check the orientation... The one you had in your photo of your actual chassis needs to be mirror-imaged: the preamp end was over by the PT and vice versa.
Also attempt to eyeball the depth that the pots will need, as you don't want to find out after installing the pots that the board won't fit.
Offline purpletele
« Reply #15 on: February 23, 2018, 02:48:28 pm »
Thank you,
I purchased a Classic Tone Stand up transformer which opens things up quite a bit.  I am going to be watching the room that I have for the POTs as well.
I think it should be much more comfortable now for space.
BV
Offline purpletele
« Reply #16 on: April 25, 2018, 04:59:09 am »
Princeton in a Champ Update
This amp has come together quite nicely.  I am using a classic tone stand up transformer and a 20 watt OT.
Believe it or not it started right up without issue and it is very quiet, maybe slighter more quiet than my other Princeton Tall Boy.
The original offset speaker baffle that I failed to specify correctly certainly didn't work for this amp so I have Mather building a new baffle and grill.
I am very pleased, I think I'll document voltages and wait for the new grill.
Videos forthcoming
Offline MFowler
« Reply #17 on: April 25, 2018, 05:59:55 am »
Nice job on that Prince-Champ it will be a great jam machine.
Mark
« Reply #18 on: April 25, 2018, 11:14:34 am »
Very nice .. !  It'll be great to see it in a cab.  :icon_biggrin:
Offline purpletele
« Reply #19 on: April 25, 2018, 06:37:47 pm »
A Stack of Princeton's
The Princeton in  a Champ is whisper quiet at idle
The HPR is very quiet but not as quiet as the PIAC.
I am regretting the use of the standard OT mounting holes to place my OT on the HPR.  I would have moved the transformer much further away but that thought just past by me when I was bolting up the engine.
I used the exact same grounding system on both amps.  There two different sets of transformers, one is a Classictone, the others are from Allen Amplification.
Offline purpletele
« Reply #20 on: May 03, 2018, 03:01:15 am »
Finished Product
this is a very cool amp!  It's a 28 lb, 20 Watt Princeton.
« Reply #21 on: May 03, 2018, 04:14:13 am »
Sharp dressed amp!  :thumbsup:
Offline purpletele
« Reply #22 on: May 03, 2018, 04:23:41 am »
Thanks Steve, it sounds really full with that Weber Speaker.
I'm very pleased.
« Reply #23 on: May 03, 2018, 01:53:59 pm »
First time seeing this thread - looking & sounding good Brian!
Offline purpletele
« Reply #24 on: May 03, 2018, 07:38:59 pm »
Thank Joe,
I have a few more projects stacked up as well.
Next is the HoSo 56 6BM8 that I worked on with Tubenit.
Then I am building another Plexi with the Mod5 changes to see how that works and sounds.
I bought a Chravel San Dimas and I think I am going through a mid life thing.  I bid on a Jet City 50 this morning and got it for $300, I promptly order a Friedman Mod kit, so that will be fun to peek into the Soldano world a bit.
BV
« Reply #25 on: May 03, 2018, 10:04:50 pm »
That’s all good stuff but hopefully you can get that un-lucky deluxe reverb working first!? Enquiring minds gotta know???
Offline purpletele
« Reply #26 on: May 03, 2018, 11:46:54 pm »
I'm hoping to get sometime booked the next couple of days with a colleague that is going to run through some tests.  It bothers me greatly, and I know that amp is going to sound fantastic.
Question on the Princeton in a Champ
The amp sounds fantastic all the way until I dime it then it starts to get wobbly, but it seems like possibly the amp just vibrating too much in that tiny box, or maybe the sound waves vibrating the 6 v 6 tubes?
I changed speaker from a Weber Ferromax to a WGS 10GS and that helped for some reason that I am not sure about yet, I need to check out the speaker specs.
The bass seems to be very strong.  I need to turn the bass to about 2-3 to get the tone stack working well, but that is too much bass when the amp is dimed and it seems to contribute to the breakdown.
Should I look at changing the Pot to a higher value?  It's 250K Audio as specified, or should I consider changing the cap to something smaller,  it's a .0047 uf as specified now.
This might also be a condition where a SS rectifier might tighten up the bass on this little gem.
Any thoughts or recommendations?
BV
« Last Edit: May 04, 2018, 12:08:18 am by purpletele »
Offline purpletele
« Reply #27 on: May 04, 2018, 12:13:27 am »
Pete,
I want to try a SS rectifier for this little amp to tighten it up.  Can you recommend a product or size that you use?
BV
« Reply #28 on: May 04, 2018, 02:42:32 am »
Pete,
BV
i use uF4007 in 50W and less. uF5408 for 100W amps. if you installed a rectifier socket, build the rectifier strings in a octal base.
Offline purpletele
« Reply #29 on: May 04, 2018, 03:28:27 am »
Pete,
BV
Thank you
Offline bnwitt
  • Crankin' out the tone.
« Reply #30 on: May 04, 2018, 09:01:06 am »
farting bass can sometimes be eliminated with the addition of a choke in the power supply.  Doug's 5E3 is an example of where that is done.   Also, to eliminate the cabinet or speaker as the problem plug the amp into a different higher wattage cabinet.  You can also alter the coupling cap(s) or cathode bypass cap in the signal chain to reduce some of the bass frequencies getting through to the power section.  Remember the power supply may be being taxed by low frequencies you can't even hear and that will put a drain on the power supply circuit.  Also, Leo's amp circuits were designed for his single coil guitars and without changes many humbucker guitars have too much low frequency signal output on certain settings.
« Last Edit: May 05, 2018, 08:37:42 am by bnwitt »
« Reply #31 on: May 04, 2018, 09:21:58 am »
Nice work purpletele...looks and sounds GREAT!
Shave some bass by lowering the value of C24 and C25 down to .02uf
This will tighten things up and help that 10" speaker cope
I'm assuming you mean .047uf, but .047 in the schematic is the MID cap
« Last Edit: May 04, 2018, 09:25:09 am by SILVERGUN »
« Reply #32 on: May 04, 2018, 11:10:02 am »
Great Looking Build.
I have built a number of PR's and the bass has always been heavy whe I do not use a PR ouput transformer in stock cap configuration, however if it is pluggen into something like a D130 JBL it simply carries it better.  If I build a Princeton and use a deluxe output iron it is even more bassy.
I have heard a lot of suggestions for cap changes on Princetons and different folks like different ways.  Some shave in mulitple locations.  I simply switch the first bypass cap from 22uf to 4.7uf.  It is easy and removes the flub, but I still have a spongy feel of a Princeton, but since I really like everything, I would probably dig a SS rectified version with cathode bias, who knows. :laugh:
Offline purpletele
« Reply #33 on: May 04, 2018, 02:03:55 pm »
Thanks Silvergun,
I tried but it didn't do the trick.
This amp is performing very well, it's that last section of the volume knob that puts it into slight chaos, which I understand is typical of this amp.
Next step is to try a SS rectifier.
Offline purpletele
« Reply #34 on: May 04, 2018, 02:05:37 pm »
Thank Ed,
That will be my next test.
Offline dude
« Reply #35 on: May 04, 2018, 02:49:57 pm »
I'm very pleased.
Is that a ten inch speaker in that champ DX cab?. And what is the model, can't seem to find it on Weber's site.
I'm wondering if I can fix a 10" in my 66 Vibro Champ (6L6) without changing the baffle keeping the 8" hole with a ten...?
al
« Reply #36 on: May 04, 2018, 03:02:18 pm »
Thanks Silvergun,
Ok, I'll take another stab at it...
One simple trick to try would be to just tack/clip a 1M resistor across the volume pot, effectively making it 500k, which will shift the cutoff frequency a bit higher.
Obviously, Ed and other's suggestion of smaller bypass cap values is another solid route.
Offline purpletele
« Reply #37 on: May 04, 2018, 03:37:12 pm »
Thanks Silvergun,
Thanks!  How fun, I’ll try that
Offline purpletele
« Reply #38 on: May 04, 2018, 07:45:20 pm »
I'm very pleased.
al
That's a Weber 10150f I believe, its a 50 watt speaker.  I haven't found data on the speaker yet.
The cabinet is one that I had Peter Mather build, it has a 10 inch baffle.
I have a 10" baffle with the off set speaker in White Cane if you need one.
I also have some black speaker grill material.
I don't know if the 10" speaker will work.
Offline purpletele
« Reply #39 on: May 04, 2018, 08:30:12 pm »
The by pass change made the most difference at this point.
I tacked on a 1 meg resistor and that worked for the frequency cut off, I think, but it was still getting muddy when dimed.
I have a SS Weber Rectifier coming to try.
What if I went with 5881's ?  I think I would have to reduce my Bias resistor from 82K down to 68K or in that range to make the bias balance out.
Offline purpletele
« Reply #40 on: May 04, 2018, 11:31:59 pm »
I used a Classic Tone 40-18090 OT on this one.  I had used the TO26 on the other Princeton.  I'll AB them and see if I have that issue on both or just the Classic tone.
I'm not going to do anything else until I try a SS Rectifier.  That will be early next week.  If that doesn't solve that 1% issue then I may change OT's.
Thanks for the advice
BV
« Reply #41 on: May 05, 2018, 05:52:13 am »
The reason I cut at the first bypass is the frequencies will never enter. If they do not enter, you do not attenuate using the tone stack and the bass knob moves from 2 max providing wider range.
I do not know of a common issue for the Princeton to be different when volume is maxed. I question this and would check where it is coming from.
Also, I will add. My best sounding 10 inch speaker ceramic is actually a Celestion vintage 30. The alnico  gold is my  favorite new.
« Last Edit: May 05, 2018, 06:02:39 am by Ed_Chambley »
« Reply #42 on: May 06, 2018, 01:57:42 pm »
Been busy Brian, here’s what I’d do at this point because you’ve tried reducing the bypass cap, coupling cap, bass, cap, speaker, etc.
You are just getting too much signal it appears. The lowering of vol value via the resistor across the vol places more of a load to the signal thereby reducing it. Instead you will create a voltage divider here involving the Volume pot by soldering in 220k resistor in-line between the signal wire feeding the pot lug - directly to the lug even. Super simple & easy to install and remove/replace. When turned up you won’t get all of that last bit causing you issues. You may be able to restore any bass you may feel you have lost from the prior adjustments if wanted?
If the added resistance seems to knock away any slight treble you feel has changed? Then put a 100pF across the 220k.
If the 220k isn’t enough increase to 470k. If too much the decrease to 100k. Adjust to taste as necessary?
« Last Edit: May 06, 2018, 04:16:22 pm by jojokeo »
Offline purpletele
« Reply #43 on: May 06, 2018, 04:12:40 pm »
You are just getting too much signal it appears. The lowering of vol value via the resistor across the vol simply places more of a load to the signal thereby reducing it a tad. Instead you will create a voltage divider here involving the Volume pot by soldering in 220k resistor in-line between the signal wire feeding the pot lug. Super simple & easy. When turned up you won’t get all of that last bit causing you issues. You may be able to restore any bass you may feel you have lost from the prior adjustments if wanted?
If the 220k isn’t enough increase to 470k. If too much the decrease to 100k. This should fix your issue no doubt?
Thanks Joe, I'll try that a little later today.
BV
Offline purpletele
« Reply #44 on: May 06, 2018, 08:47:12 pm »
Joe,
Thanks, that worked perfectly!  I am going to adjust the other Princeton as well.
BV
Offline bnwitt
« Reply #45 on: May 08, 2018, 08:04:37 am »
Brian,
Which of Joe's suggestions did you implement?
Offline purpletele
« Reply #46 on: May 08, 2018, 12:26:34 pm »
Brian,
Barry,
I soldered a 220K resistor in line on the volume lead.  It seemed to solve my issue.
I can dime the Princeton and have a solid, slightly distorted note.
I am very pleased.
BV
« Reply #47 on: May 08, 2018, 04:22:37 pm »
Hey Joe,  Love doing that!
If you think, and I agree since the results show, he has too much signal.  If this signal is simply from pickups plugged into the amp without anything like a booster or active pups, wouldn't you think raising the PI voltage and checking for some balance would be in order.  What I am saying is it will scream a bit more
Offline purpletele
« Reply #48 on: May 08, 2018, 04:50:57 pm »
Ed,
I have that amp working perfectly, well beyond a standard Princeton.  It is very impressive now.
I went to tweak my other Princeton that was rock solid and inadvertently broke a wire on V2.  So after I finished surgery I played it for a few minutes and the it burned a fuse.  So I think I have it worked out but I’m chasing fuses.
This would be the amp for me to try something clever if you have a blessed idea.
Otherwise I’m good with getting it back to solid.
BTW, I have some Weber SS Rectifiers to try once I get the amp corrected.
BV
« Reply #49 on: May 08, 2018, 10:44:56 pm »
Shhsh Ed, these kind of things are secrets of the ninja! Ha! 😉
I will do a lot of things like this on my own stuff or on others but it gets complicated quick and time consuming over the net without being there. Plus Brian was already doing a lot of stuff which is trying and frustrating, didn’t want to add more just give him a solution.
I have emphasized to him that just because an amp is working after being built doesn’t mean its done or performing optimally and to embrace this aspect. Besides, after his unlucky deluxe build issues he needed some confidence building blocks from these and think he got it. Well deserved too.
