August 05, 2026, 05:51:29 am
Hoffman Amps Forum image Author Topic: can't figure it out  (Read 7109 times)
can't figure it out
« on: February 18, 2018, 03:27:41 pm »
'm ooglin schematics for my next build and I find this;
I'm looking at V1b :dontknow:
my guess is it's common grid :dontknow:, some sort of AGC :dontknow:
Re: can't figure it out
« Reply #1 on: February 18, 2018, 04:17:07 pm »
Also the OT winding at cathode is a bit odd to me
not the winding at cathode itself, but the intake that goes to pin number 5 of the connector ....  :w2:
Offline VMS
« Reply #2 on: February 18, 2018, 04:23:37 pm »
Some kind of voltage regulator maybe  :dontknow:
« Reply #3 on: February 18, 2018, 04:52:14 pm »
If you look at the legend, they use that as the  70.7v type line out, inductors were once considered cool :laugh:
I'm really only interested in a V1 phono preamp circuit that's odd :icon_biggrin:
« Reply #4 on: February 18, 2018, 05:25:58 pm »
 :BangHead:  I'm even more confused, I can't get B+ to V1a :think1:
I'm now leaning to some sort of PI???, I'm redrawing it so I can see better :dontknow:
« Reply #5 on: February 18, 2018, 05:41:06 pm »
V1A plate current path flows through R8 to V1B cathode to V1B plate to C12C.
Offline VMS
« Reply #6 on: February 18, 2018, 05:53:49 pm »
« Reply #7 on: February 18, 2018, 06:04:09 pm »
You folks are amazing, thanks
I also just sorta skipped over the "preamp" part of the connector and read "input" :think1:
I found the revised schematic that eliminates the neon's, then found type 125 that eliminates the regulator :think1:
« Reply #8 on: February 18, 2018, 06:54:08 pm »
ok, think I get it, maybe. I redrew V1, if I tweak R5/R31, I change V1a's plate voltage?
Is there something I'm missing if I feed my own "next" gain stage?  can I keep it DC coupled?  or is it better to cap couple?  I'm going for SE vs the PP
« Reply #9 on: February 18, 2018, 08:35:09 pm »
> SE vs the PP
Anyway--- That's a McIntosh. Mere Mortals are not supposed to understand. The killer detail is the unity-coupled OT, something NO other maker ever attempted. The flip-side is that it needs HUGE signal at 6550 grids. McIntosh was full of too-clever ideas. To sell them, he put every bell and whistle on. Great amps, but not for you.
That's not a suitable steal-point for a guitar amp.
« Reply #10 on: February 18, 2018, 09:05:35 pm »
this idea is a mono-block 10-20W.  I want a phono level in and something that can deal with 1-2vac in.  It's more about "that's unique", also, can I make it variable, if so, I can scope the effect of changing DC plate, on AC signal :dontknow:
I also found a meter circuit from one of my early hero's, Mr. Mims
« Reply #11 on: February 19, 2018, 08:02:20 pm »
here's the 1st draft pre-section.  the PA will be one I used before, QSE EL84's
not all the values are there yet, any that are, I'm open to recommendations
I named it, now I gotta build it, slowly, probably start with a new BB rev 3 :icon_biggrin:
« Reply #12 on: February 20, 2018, 11:57:46 am »
It's 62degrees!!!  so I tore down the donor chassis.
3.5kw mod-sinewave invertor that I, um, forgot to switch out when the grid came back :cussing:
prune 5.6
« Reply #13 on: February 23, 2018, 04:28:55 pm »
finally found all the Iron :think1:
250v 200mA PS
10H 200mA choke
25W UL OT
now I need casters :BangHead:
Re: prune 5.6
« Reply #14 on: February 24, 2018, 11:23:05 am »
250v 200mA PS
10H 200mA choke
25W UL OT
 :laugh:
« Reply #15 on: February 24, 2018, 11:48:08 am »
I bread boarded the panel meter last night, probably have a switch to monitor input, or output of the preamp.
« Reply #16 on: February 27, 2018, 09:40:28 pm »
got 2 many fires going so I took the Hammond 270HX and plugged it in, PT test into a 5K load gets 408vdc with a fullwave, ct grd.  I haven't had an amp since Christmas,  :sad2:, and I'm not even a player :think1:
hopefully by the weekend
