October 05, 2026, 09:18:02 pm
Hoffman Amps Forum image Author Topic: Attaching chassis to head cab  (Read 5401 times)
Offline Big_Mike
« on: March 05, 2018, 10:34:32 am »
I am working on completing a project using the Hoffman stout chassis, and need to attach it to a head cab box.  What is the preferred method?  Screws and keps nuts?  Any help would be appreciated.  Thanks.
Offline Big_Mike
Re: Attaching chassis to head cab
« Reply #1 on: March 06, 2018, 09:09:37 am »
Can anyone help me with the hardware needed?  Thanks.
« Reply #2 on: March 06, 2018, 09:28:41 am »
I use bolts, split ring lock washers, and nuts.  I never use screws.
Offline MFowler
« Reply #3 on: March 06, 2018, 09:34:38 am »
On my Hoffman chassis I just drilled cabinet holes and used long 10-32 bolts with keps nut you can use nylock or plain nut with lock washer.
You can also use nut inserts steel, not the aluminum ones, stronger.
Or you can use those slip on captive nuts.
Mark
