August 05, 2026, 08:41:05 am
Hoffman Amps Forum image Author Topic: 5E3 voltages not right any suggestions?  (Read 11495 times)
Offline leevc5
« on: March 16, 2018, 04:18:50 pm »
B+ off of 5Y3 without other tubes installed is 470 - that seems OK
but
B+ with tubes installed drops to 240? Should be ~360
6V6 pin 8 cathode 48V??? Should be ~20
What might cause this weird voltage stuff?
Have swapped out all the tubes and readings are consistently puzzling.
Also, when power switched on after a couple of seconds there is a pop or click noise. Doesn't continue or repeat, just one time every time powering up.
Re: 5E3 voltages not right any suggestions?
« Reply #1 on: March 16, 2018, 04:24:37 pm »
6V6 G1 voltage??
« Reply #2 on: March 16, 2018, 04:27:49 pm »
What is the voltage on pin 5 of each 6V6? Should be zero.
Offline leevc5
« Reply #3 on: March 16, 2018, 04:41:46 pm »
When measuring pin 5 on each 6V6 starts at ~1.6 and drops tp .5V and stays there.
« Reply #4 on: March 16, 2018, 04:59:44 pm »
Disconnect both coupling caps between the PI plates and 6V6 grids and recheck the voltage on pin 5 of each 6V6.
Offline leevc5
« Reply #5 on: March 16, 2018, 05:03:17 pm »
6V6 G1 voltage??
where/how do I measure G1 and what is it?
« Reply #6 on: March 16, 2018, 05:05:14 pm »
G1 = pin 5
Offline leevc5
« Reply #7 on: March 16, 2018, 05:10:05 pm »
With coupling caps disconnected from PI still reads .5V but does not start higher and drop down just immediately .5.
« Reply #8 on: March 16, 2018, 05:28:40 pm »
With those two caps still disconnected do the B+ voltage readings go up? And does the pin 8 voltage go down to a more reasonable value?
Offline leevc5
« Reply #9 on: March 16, 2018, 05:33:06 pm »
B+ still low ~254 but pin 8 now at 24 which is more in line.
« Reply #10 on: March 16, 2018, 05:40:14 pm »
Reconnect only one of those caps and then recheck pin 8 voltage. If voltage goes up, replace that leaky cap and recheck pin 8 voltage. If still approx. 20 volts, install the other cap. If voltage goes up, replace that leaky cap and recheck pin 8 voltage. If still approx. 20 volts, throw away the leaky cap(s).
With power off, measure resistance between chassis and pin 5 of each 6V6. What have you?
« Reply #11 on: March 16, 2018, 05:47:53 pm »
Old build, new build?
i.e. did it work right once or are you first-time smoke-testing?
Offline leevc5
« Reply #12 on: March 16, 2018, 06:12:12 pm »
Thank you for your patience and persistence.
Unfortunately, just took a step backwards. Tried the leaky cap replcement process without success and now with both caps disconnected am back up to 48V @ pin 8?????
Offline leevc5
« Reply #13 on: March 16, 2018, 06:13:15 pm »
New build, first time to fire it up.
« Reply #14 on: March 16, 2018, 06:13:45 pm »
OK, so it ain't the caps. What about the resistance check?
Offline leevc5
« Reply #15 on: March 16, 2018, 06:43:34 pm »
Infinity - Open Loop
« Reply #16 on: March 16, 2018, 06:52:21 pm »
You are most likely missing a ground connection to the junction of those two 220K grid resistors. Fix it and things will get a lot better.
If this is a Hoffman board the most likely problem is a missing under board jumper from the junction of those two 220K resistors to the negative terminal of a 16µF filter cap. If using another layout just look.
Offline leevc5
« Reply #17 on: March 16, 2018, 07:07:27 pm »
That Dr. Sluckey sir was the problem!
You got me thru many a 5F1 weirdities and have got me thru my first 5E3 build to success. If there was a Nobel prize for Tweed Amp Troubling Shooting you should certainly win the award.
Thank you one again.
« Reply #18 on: March 17, 2018, 04:49:39 am »
+1              Sluckey definitely holds the record for correctly trouble shooting my amp builds!
with respect, Tubenit
« Reply #19 on: March 17, 2018, 05:06:49 am »
He also holds the record correctly shooting amp builder problems.
« Reply #20 on: March 17, 2018, 07:43:51 am »
I try to treat all equally. Give'm what they ask for.  :icon_biggrin:
« Reply #21 on: March 24, 2018, 12:45:28 pm »
 :laugh:
