August 02, 2026, 12:11:03 pm
Hoffman Amps Forum image Author Topic: Grounding layout for Hoffman Stout.  (Read 10237 times)
Offline Oddvar
« on: June 13, 2018, 04:14:27 pm »
Hi.  I am a bit uncertain on what to ground on a Hoffman 18w stout.  Can anyone enlighten me?
Offline Oddvar
Re: Grounding layout for Hoffman Stout.
« Reply #2 on: June 14, 2018, 02:07:34 am »
 The pots seem to have 3 groundings, I am a bit uncertain about where the filter cap grounding from the pot would be on the Stout?
I suppose the CT of the heaters go there to? Then I won't need the 100rs from the pilot lamp?
« Reply #3 on: June 14, 2018, 06:55:26 am »
There are only two ground points in the Stout. One is called the "Ground Buss". The ground buss is just a stiff length of wire that runs behind the pots and actually connects to chassis via the input jack ground lug. Some people solder the ground buss to the back of the pots. I don't. I just float the ground buss above the pots and support it with short wires that connect to the appropriate pot lug and the input jack ground lug. The preamp grounds on the left side of the board also connect to this "Ground Buss". All this is clearly shown on page 5 of the Hoffman_Stout.pdf.
The second ground point is called "Chassis Ground Lug". It is simply a ground lug bolted to the chassis near the PT. Many people use one of the PT bolts for this Chassis Ground Lug. The PT center taps connect to this lug. The cap can negative terminal connects to this lug (If you use individual filter caps then connect the negative lead of all 4 caps to this ground lug). Page 4 clearly shows these grounds. The power grounds on the right side of the board also connect to this lug (see page 5).
The IEC ground wire should connect to a separate ground lug near the IEC connector. Nothing else should connect to this ground lug. This is the preferred way to ground the IEC. (Hoffman simply connects it to the "Chassis Ground Lug.)
The  speaker jacks provide the ground connection for the OT secondary (not really needed).
« Last Edit: June 14, 2018, 06:59:48 am by sluckey »
« Reply #4 on: June 14, 2018, 09:01:38 am »
Are you looking at my layout diagram .pdf file?
You need to look at all the documents for that board on the library page
Steve posted the link
Offline Oddvar
« Reply #5 on: June 14, 2018, 11:26:04 am »
Hi and thanks.  Being a hobbyist builder, grounding issues can sometimes be a bit confusing on layouts.  Sorry if it seems untimely.
This helped.
Offline Oddvar
« Reply #6 on: June 15, 2018, 02:53:09 pm »
I have now checked all the voltage points as described in the schematics.  Al the voltages ar as described, give an take 5/10%, but mostly a  bit lower.  I am beginning to suspect that the build might be a bit noisy in the first place?  When the volume is a zero, there i s very distinct "G"-ish tone ringing, not so loud as it were.  When I put into it a EL86 tube, it was not lower, but still there.
« Reply #7 on: June 15, 2018, 03:02:51 pm »
My build is dead quiet
It's hard to tell the amp is on
« Reply #8 on: June 15, 2018, 03:19:13 pm »
Temporarily disconnect the feedback wire. Any better?
Offline Oddvar
« Reply #9 on: June 15, 2018, 04:39:19 pm »
No, it's no change.
« Reply #10 on: June 15, 2018, 06:29:37 pm »
Show us some hi-rez pics of your amp.
Offline Oddvar
« Reply #11 on: June 16, 2018, 08:06:07 am »
Could hum come from some fault in either the OT or PT?
« Reply #12 on: June 16, 2018, 08:15:53 am »
You've had hum in several of your projects. I wonder if there is something common to all your builds that produces hum. Did you ever resolve the hum issues on your other builds?
« Reply #13 on: June 16, 2018, 08:21:39 am »
Where is the picture that Steve requested?
Offline Oddvar
« Reply #14 on: June 16, 2018, 10:52:40 am »
This is the only amp I haven't managed to get rid of the hum in.
My builds are:
Fender Bassman, Marshall Plexi, Soldano Slo, Vox AC30, 2 Fender Champ, Fender Pro Jr., Marshall 2204, VHT 10w, Epiphone valve rebuild.  At the moment I am building another 18w Marshall.
I have had issues with some builds, none I haven't managed to solve, some from the good people of this forum, some from others.
But I am doing this just for fun, as a hobby.  I am no expert at all.
I will post pics in a while, at the moment I am rewiring some parts.
« Reply #15 on: June 16, 2018, 11:34:40 am »
Soldano Slo
I try and keep notes when I help out, what was the solution on this one, if you don't mind?
Offline Oddvar
« Reply #16 on: June 16, 2018, 12:13:10 pm »
Two bad solderings on the 0ohm resistors.
« Reply #17 on: June 16, 2018, 07:06:57 pm »
Yes.
Offline Oddvar
« Reply #18 on: June 17, 2018, 10:10:47 am »
Hi again guys.  Just for the conclusion: I changed the volume pot and resoldered one cap and one 100k resistor, and the hum was gone, as mr EL34 stated, I can barely hear that it's on.  Thanks for all your help.
« Reply #19 on: June 17, 2018, 10:30:13 am »
THANK you for posting your solution and success!   It helps the rest of us when we run into something similar.
« Reply #20 on: June 17, 2018, 11:44:42 am »
Always good to know what the solution is. Thanks.
Offline Oddvar
« Reply #21 on: June 17, 2018, 12:48:59 pm »
Thanks to you Sluckey, for all your efforts, hope I didn't strain your patience.
