September 08, 2026, 05:44:04 pm
Hoffman Amps Forum image Author Topic: Belton Reverb Brick  (Read 44586 times)
Re: Belton Reverb Brick
« Reply #50 on: August 11, 2018, 01:30:48 am »
Thanks mate, I'll give'em a bash.
« Reply #51 on: August 12, 2018, 04:30:07 am »
Hi guys, I have had some success....
Adding the 220k mix resistor has added another problem.
It lets the dry signal pass with the reverb pot turned to zero, but it also lets a full strength dry signal through to the amp input.
So it acts like an overdrive pedal, which is not a bad thing.
I connected the 220k to the wiper of the trim pot, this has helped to reduce the dry signal but it also looses signal it the trim is turned to 0.
Inturn if V1b does not have the reverb pot turned up enough the tremolo won't work and then if the reverb pot is turned up there is too much reverb.
Side note, connecting the trem to V1a cathode sounds crap.
I might try putting the reverb pot between the brick and V1b.
 :think1:
« Last Edit: August 12, 2018, 04:41:07 am by TIMBO »
« Reply #52 on: August 12, 2018, 05:19:54 am »
Watching this with great interest!  Thanks for sharing your build and schematic.  Looking forward to seeing what you come up with that you're
most favorable towards.
« Reply #53 on: August 12, 2018, 11:58:21 am »
There's much too much gain to be a straight-through signal path.
Try a 50K resistor on the output jack.
« Reply #54 on: August 13, 2018, 02:56:53 am »
Thanks PRR, Just not sure what you are asking.
« Reply #55 on: October 27, 2018, 07:46:08 pm »
Hi guys, I think this one is sorted.
Retried some of the suggested tweaks and there is now a good mix between the trem and verb.
« Reply #56 on: March 24, 2019, 02:34:16 am »
Hi guys, Put the finishing touches on this one.
With some great info from sluckey and a bit from http://www.valvewizard.co.uk/trempcb.html
The trem works great.
Offline davidwpack
    • My music on reverbnation
« Reply #57 on: March 24, 2019, 02:19:59 pm »
I recently built a reverb pedal with the Belton brick. I actually prefer it over the real spring reverb.
« Reply #58 on: June 05, 2019, 05:03:24 am »
Hi guys, With the valve circuit working well with these bricks...
Could the IRF820 type mosfet be used to replace the valve???
Offline tristanc
« Reply #59 on: June 05, 2019, 08:41:18 am »
Don't see why not. I used a TL072 as input buffer and make-up (just like a pedal) and it seems to work well. No need for high voltages. I used LND150s for my loop (following MOSFET Follies, normal B+ voltages) with the reverb hardwired in the return section. Very happy with it so far.
« Reply #60 on: June 06, 2019, 04:32:50 am »
Thanks mate, I was looking to modify this
In a way I could remove the transformer and connect the brick input to Q1
« Reply #61 on: June 06, 2019, 08:58:43 am »
I would think the bottom of C1 1st, if there isn't enough drive then maybe you'd need Q1 to drive the brick  :dontknow:
« Reply #62 on: June 06, 2019, 04:39:09 pm »
No. Q1 outputs a hundred volts signal. The Brick needs like one volt signal. If it worked it would blow up the brick. However it won't do anything without some DC feed to Q1, a transformer or resistor.
Do the opamp plan in #59.
« Reply #63 on: June 07, 2019, 01:46:46 am »
Thanks PRR, That's all I need to know. :thumbsup:
« Reply #64 on: June 07, 2019, 01:49:29 am »
Thanks, tristanc  :thumbsup:
Offline tristanc
« Reply #65 on: June 11, 2019, 02:55:06 am »
If you want I could send you one of my reverb PCBs I had made up? £5 + shipping. Might save you some time.
Let me know.
Am very pleased with the resulting sound and there's scope for adding more controls (length of reverb and tone) to the front / rear panel if desired.
Tristan
« Reply #66 on: June 17, 2019, 01:13:30 pm »
Tristanc,
Are the two back to back zeners for protection or to limit possible distortion to the inputs of the LND's?
Offline tristanc
« Reply #67 on: June 18, 2019, 04:00:17 am »
They're to protect the LND150s if they get heavily overdriven.
Here's the thread where I went through development:
https://www.diyaudio.com/forums/instruments-and-amps/325029-adding-belton-reverb-module-pedal-amp.html
And the specific post on the zeners: https://www.diyaudio.com/forums/instruments-and-amps/325029-adding-belton-reverb-module-pedal-amp-post5492663.html
