August 15, 2026, 10:59:18 am
Hoffman Amps Forum image Author Topic: Transformer Question  (Read 4502 times)
Offline JKRamsey1991
« on: August 05, 2018, 08:19:05 pm »
I have an output transformer that was given to me. It is a Weber 40 watt with 4K impedance. I was thinking of using it in a new 2 6V6 build. If I use it in this build, what impedances would the taps in effect be with the 6V6s? The transformer has 2, 4 and 8 ohm taps.
Re: Transformer Question
« Reply #1 on: August 05, 2018, 08:28:12 pm »
Call the secondary taps 4, 8, and 16.
« Reply #2 on: August 05, 2018, 08:29:40 pm »
Thanks Sluckey! That’s what I thought was the case but wanted to make sure I didn’t have it backwards!
« Reply #3 on: August 05, 2018, 09:47:22 pm »
tube chart I checked;
285plate 8k eff plate2plate
although 250plate = 10k
when you land your Plate volts and tube current, then you might decide to play around n see what's best for you
« Reply #4 on: August 06, 2018, 08:08:37 am »
Plate voltage will be higher as I will be using a deluxe reverb power transformer. I just wanted a safe baseline so I wouldn’t kill the OT or the tubes.
