September 16, 2026, 02:28:45 pm
Hoffman Amps Forum image Author Topic: multi-section capacitor replacement advice  (Read 4446 times)
Offline Oldgem
« on: September 04, 2018, 04:25:01 am »
I have an old Italian 30W beast made by GEM called a Mars. They named all their amps after Roman gods. The Mars has a multi-section capacitor which I need to replace. There is plenty of room on the chassis so am not averse to a modern solution. How can I do this please? Here is a pic of the offending part which I simply can't find a replacement for. Any pointers would be gratefully received. It is a 500V 40uF - 20uF - 30uF. Thanks.
Re: multi-section capacitor replacement advice
« Reply #1 on: September 04, 2018, 06:56:04 am »
Doug sell a JJ 40-20-20-20uF 500V that you can use (connect two 20uf section in parallel so you have 40-40-20uF)
https://hoffmanamps.com/MyStore/perlshop.cgi?ACTION=enter&template&thispage=Capacitors&ORDER_ID=!ORDERID!
or give a look here
https://el34world.com/Forum/index.php?topic=23667.0
Ciao
« Last Edit: September 04, 2018, 07:10:21 am by kagliostro »
