September 16, 2026, 03:59:11 pm
Hoffman Amps Forum image Author Topic: Single Channel Bassman  (Read 7978 times)
« on: October 07, 2018, 02:15:24 pm »
I have this single channel Bassman layout from Mojo. Something don't look right. Why it is not using a coupling cap to the volume pot?Is there a single channel Bassman here on the forum from Doug or others?
I found this one 6G6
« Last Edit: October 07, 2018, 02:22:13 pm by plexi50 »
Re: Single Channel Bassman
« Reply #1 on: October 07, 2018, 02:37:36 pm »
The blackface Bassman AA864 doesn't need one. This circuit is quite different from a 5F6A. The schematic explains all.
« Reply #2 on: October 07, 2018, 02:47:15 pm »
Fender brown/black face amps use the TS caps as coupling caps.
« Reply #3 on: October 07, 2018, 05:04:31 pm »
Ok im a soldering. I want to hear this tonight. Thanks all!
Offline JKRamsey1991
« Reply #4 on: October 11, 2018, 06:44:52 am »
The layout you posted isn’t cut off in the right spot. For the Norma channel only Bassman you only need two preamp tubes.
