September 16, 2026, 11:35:14 pm
Hoffman Amps Forum image Author Topic: Ampeg B15S replacement ot  (Read 5968 times)
« on: October 12, 2018, 12:54:22 pm »
Since I have to replace the ot in my ampeg B15S amp..  I ask for your consideration of this option ..
Hammond 1650HA  40 watts
Hammond 1650PA  60 watts
the amp uses two 7027A power tubes and the Plate v could be a high as 570 v due to high wall v   https://drtube.com/datasheets/7027a-rca1959.pdf
MM has one for $260   and   Mojo has one for $299   very expensive
I think I can mount this hammond under the stock transformer  can  without potting  and still have the stock look..
btw  anyone know how to de-pot a potted transformer from the 70's?   I think I would warm it up in the oven and then dump the goo out..  but  I don't know
« Last Edit: October 12, 2018, 12:57:52 pm by mresistor »
Re: Ampeg B15S replacement ot
« Reply #1 on: October 12, 2018, 06:30:24 pm »
According to what I have learned that primary impedance of the stock OT is 6K .. and resistance of 300 ohms.
« Reply #2 on: October 12, 2018, 10:56:12 pm »
Is the mojo OT potted? If so that costs more to pot the OT.
It's a bass amp so I would go with a larger/higher wattage OT, given a choice.
Many guys here have used Hammond iron, with great results.
« Reply #3 on: October 12, 2018, 11:13:46 pm »
.....the amp uses two 7027A power tubes and the Plate v could be a high as 570 v due to high wall v   https://drtube.com/datasheets/7027a-rca1959.pdf
The data sheet shows 600dcv max for the plate and 500dcv max for grid 2/screen. It also shows 600dcv max for both plate and grid 2/screen if using a tap from the plate wind (UL). UL taps limit the screen grid current.
All 4 schematics in Doug's library show 575dcv plate and 580dcv on screens with 470ohm 2w screen R's.
So use at least a 1K 5w R for the screens to help limit the screen grid current.
Real 7027's will take the dcv in your amp, so the data sheet say's and new 7027's?   :dontknow:
« Last Edit: October 12, 2018, 11:21:20 pm by Willabe »
« Reply #4 on: October 13, 2018, 10:42:23 am »
Thanks Willabe - for sure I will change the screen resistors. Crazy high voltages in this amp.
