September 15, 2026, 09:08:35 pm
Hoffman Amps Forum image Author Topic: Help biasing a Hoffman 5F6A?  (Read 5585 times)
Offline frpax
  • I have no idea what I'm doing!
« on: November 17, 2018, 11:00:02 pm »
I searched the boards and really couldn't find what I am looking for, so here I am (again) asking probably silly questions!
OK, so I got my 2x12 Hoffman 5F6A all together and I want to bias the power tubes.
AND, I do not have one of those nifty biasing devices. Just a multimeter.
I had a friend help me with this on my first amp (Plexi 6V6), and I didn't have any of those biasing devices then, so I know it can be done.
I just need someone to walk me through it or point me to a thread that explains how to bias with just a multimeter.
Thanks for any help!!
“Whether you think you can, or you think you can't--you're right.”
~Henry Ford
Re: Help biasing a Hoffman 5F6A?
« Reply #1 on: November 17, 2018, 11:35:13 pm »
Read this...
     http://www.duncanamps.com/technical/lvbias.html
All you need is a meter and a calculator. The 1Ω resistors are already installed on the Hoffman 5F6A board.
Offline frpax
« Reply #2 on: November 19, 2018, 10:15:37 am »
Read this...
Thank you!
~Henry Ford
Offline frpax
« Reply #3 on: November 26, 2018, 05:00:42 pm »
Where?
~Henry Ford
« Reply #4 on: November 26, 2018, 05:19:43 pm »
Where?
On Doug's layout drawing, 5F6A, their by the power tubes, black wire runs from pins 1 and 8 back to the turret board, 1ohm R's.
Offline frpax
« Reply #5 on: November 27, 2018, 10:40:02 am »
Where?
Ah yes! I see them now. Many thanks
~Henry Ford
« Reply #6 on: November 27, 2018, 10:53:06 am »
Same voltage reading. 370-ish
fixed bias changes G1 vdc, pull PA tubes, put meter 'tween G1 and ground and measure -vdc, rotate pot ccw read, rotate pot cw read
