September 19, 2026, 11:24:09 am
Hoffman Amps Forum image Author Topic: Mesa Rocket 44 part  (Read 7890 times)
Offline etneccas
Mesa Rocket 44 part
« on: March 20, 2019, 09:17:55 am »
I found a bad inductor in the contour part of the circuit
Falco 9749 519068
Does anyone know where I can source one?
Re: Mesa Rocket 44 part
« Reply #1 on: March 20, 2019, 09:27:09 am »
Try Mouser
Offline Papa Jim
« Reply #2 on: March 20, 2019, 09:44:08 am »
Offline etneccas
« Reply #3 on: March 20, 2019, 10:22:24 am »
Thanks Guy's......I actually dug the broken lead out of the case and measured the 2.4ohms again and it lined up with the circuitboard so I resoldered it in and she is alive again and sounds incredible
I'll still want to source the part I'll try Mesa first
Offline etneccas
Re: Mesa Rocket 44 sounds like crap again frustrated!!!
« Reply #4 on: March 20, 2019, 11:13:24 am »
Looks like I celebrated prematurely When I took the chassis off my bench where it sounded incredible and put it back in the combo cabinet it sounds like crap again
 I tried a different speaker cab and it sounds alittle better but still like crap Its back to the bench again ugh!!!!
Offline silverfox
« Reply #5 on: March 20, 2019, 01:40:20 pm »
What did you measure the inductor with? 2.4 Ohms would be a resistance, reactance, at a particular frequency. Unless you really wanted to express the answer in Ohms, it should be stated in uh.
I just found this page the other day. Lot's of audio caps and inductors: http://www.danssmallpartsandkits.net/
silverfox.
« Last Edit: March 20, 2019, 01:43:02 pm by silverfox »
Offline etneccas
« Reply #6 on: March 20, 2019, 02:17:49 pm »
The print shows .068h
The part itself is Falco 519086 9749
Offline Papa Jim
« Reply #7 on: March 20, 2019, 02:48:56 pm »
so I believe that is  .068 henry = 68 mH = 68000 uH  should be readily available lots of places. Just google or I saw them at the place silverfox mentioned.
« Reply #8 on: March 20, 2019, 02:54:30 pm »
Just go to Mouser. Search for 68mH. Over 200 hits with a wide variety of form factors and sizes. Most for about 1 buck. I'm sure there will be one that catches your eye.
BTW, that formula link requires you to know the freq and ***REACTANCE*** to calculate inductance. No way to solve for inductance based on a DC ohmmeter resistance measurement. And why would you? The inductance is given on the schematic.
Offline Papa Jim
« Reply #9 on: March 20, 2019, 02:59:37 pm »
Thanks, Steve. for the formula correction. I will see if it will let me delete that post before someone like me get's confused about that.
Offline etneccas
« Reply #10 on: March 20, 2019, 05:13:52 pm »
Will any radial 68mh be sufficient?
I’m not having any luck trying to find an exact replacement?
« Reply #11 on: March 20, 2019, 05:27:26 pm »
yup
« Reply #12 on: March 20, 2019, 05:34:36 pm »
Even if it's the size of your fist it will work. I'm partial to the little axial lead inductors that look like a cc resistor and are about the same size.
« Reply #13 on: March 20, 2019, 06:35:04 pm »
I'm partial to the ones that show all the copper winds and dipped in lacquer  :icon_biggrin:
Offline Papa Jim
« Reply #14 on: March 20, 2019, 06:40:07 pm »
I'm mostly partial to any that work.  :l2:
Offline etneccas
« Reply #15 on: March 20, 2019, 07:15:37 pm »
Ordered.....Thx guys
