September 17, 2026, 07:32:19 am
Hoffman Amps Forum image Author Topic: Advantages/Disadvantages of Diodes or Rectifier...  (Read 5230 times)
Offline newguitarsmell
« on: April 10, 2019, 02:22:16 pm »
https://el34world.com/Hoffman/files/Hoffman_Plexi_6V6-V2.pdf
I'm building this amp. Someone said I could get better cleans with a rectifier tube rather than the diodes - -
1. Thoughts?
2. If I were to change this so I could use a rectifier instead - how, exactly, would I do it and what rectifier tube would I use?
Also - this amp calls for an LED and I just have a regular fender lamp assembly. I am assuming this is not an issue - shouldn't be right? Just wire it in as normal?
Re: Advantages/Disadvantages of Diodes or Rectifier...
« Reply #1 on: April 10, 2019, 02:53:43 pm »
no expert, but I tend to expect a tighter B+, no sag, no real tonal changes from SS rect.  some might call it stiff vs warm, I'm not a musician, I just want my B+ to stay reasonably constant, so I've only used 1 tube rec., then I moved to diodes and never looked back.
if you mean to the AC ;ine volts, yes, if you mean in place of LED, no.
« Reply #2 on: April 10, 2019, 04:21:05 pm »
1. Some one is lying.
2. Like this... http://sluckeyamps.com/6v6plexi/6v6plexi.pdf
Not an issue.
