September 16, 2026, 12:05:02 am
Hoffman Amps Forum image Author Topic: NFB  (Read 4997 times)
Offline newguitarsmell
NFB
« on: June 06, 2019, 10:42:11 pm »
How important is it to hook up the NFB?
I didn't use it on my small watt amps - would I need it on the Plexi style?
https://el34world.com/Hoffman/files/Hoffman_Plexi_6V6-V2.pdf
Re: NFB
« Reply #1 on: June 06, 2019, 11:04:38 pm »
It has a big effect on the way an amp sounds. How important is that?
Re: NFB
« Reply #2 on: June 07, 2019, 12:42:22 am »
I will have to hook it up and give it a listen!
Offline Papa Jim
Re: NFB
« Reply #3 on: June 07, 2019, 06:06:02 am »
It just goes to show ya.  :l2:
Re: NFB
« Reply #4 on: June 07, 2019, 07:29:56 am »
Without NFB the presence control won’t have any effect. Of course a Vox style tone cut control arrangement could be used in that front panel location.
Offline ALBATROS1234
Re: NFB
« Reply #5 on: June 07, 2019, 09:11:15 am »
If I understand nfb right a Marshall without it may sound harsh and distorted in an unpleasant way at least to some extent. And a presence control on a Marshall is basically variable nfb right? That circuit is designed to have that type and value of nfb so without it there's no telling if it would even sold like marshall.
Offline vampwizzard
    • Walbertedwards.com
Re: NFB
« Reply #6 on: June 07, 2019, 10:02:46 am »
Presence control is an eq stage applied in the NFB loop vs a pot which would vary the amount of NFB you inject back into the system.
the Aikenamps article on NFB explains the impact pretty well.. may be worth a search.
Offline Jennings
Re: NFB
« Reply #7 on: June 10, 2019, 03:44:02 am »
I tend to prefer designs without NFB at all...but i like my amps much more organic and chewy than most these days.  Worth maybe temporarily hooking up a bit of NFB, playing the amp, then try cutting the NFB and see what you prefer...or simply put a couple of switches in for NFB/no NFB and another for different values of components.
