August 29, 2026, 04:56:14 pm
Hoffman Amps Forum image Author Topic: turretts and eyelets  (Read 7862 times)
Offline jim
« on: July 13, 2019, 07:27:40 pm »
I am building Sluckeys AC-15 board. It is very complex.  I cant seem to get more than two components wires into the turret.  It is especially difficult when an under board jumper is hooked over the top.  Should I wrap the additional components or parallel solder to adjacent leads?  I have made eyelet boards and this is never a problem.  Its a basic question but I need to know before I solder.  Thanks Jim
Re: turretts and eyelets
« Reply #1 on: July 13, 2019, 07:37:47 pm »
I believe Sluckey used 1/4w R, IIRC maybe 4 or 5 leads per turret  :dontknow:
« Reply #2 on: July 13, 2019, 07:43:08 pm »
That's why I use 1/2w metal film resistors. I can easily fit 4 leads in one turret. I also use 22awg jumpers. You'll find that all my later layouts are arranged based on using skinny leads.
Offline jim
« Reply #3 on: July 13, 2019, 08:18:26 pm »
Well I have plenty of carbon comp resistors with extra long and fat leads.  Ill tack em in the best I can.  Jim
« Reply #4 on: July 14, 2019, 05:48:36 am »
This is where eyelets work way better if you are trying to stuff many leads into a terminal
Do jumpers and hookup wires around the base of the lugs
I do under the board jumpers into the under side of the lugs
In my board build instructions, there are some pics of how I like to wire boards
https://el34world.com/Hoffman/instructions.htm
« Reply #5 on: July 14, 2019, 06:39:13 am »
Exuse me for the hijack
Just to have confirm
the little ones on this board are 1/2W metal film resistors ?
« Reply #6 on: July 14, 2019, 07:31:04 am »
Yes, the ones Hoffman and AES sell.
« Reply #7 on: July 14, 2019, 07:47:49 am »
Thanks Steve
« Reply #8 on: July 14, 2019, 11:00:55 am »
Probably yes.
But it is getting hard to tell. Resistor sizes for power used to be pretty standard. But modern resistors use higher temperature material and may be rated for higher power in small size. I have seen what I thought were 1/2W parts carrying a 3W rating (they must glow dull red at that power).
« Reply #9 on: July 14, 2019, 11:26:59 am »
It is getting hard to tell. You sure can't go by size when looking at different types of resistors. Look at the two black resistors just below the Atoms bias caps in this pic. They are rated 1Ω, 1%, 1W. About the size of a 1N4007 diode.
     http://sluckeyamps.com/6v6plexi/P-6V6_05_big.jpg
« Reply #10 on: July 14, 2019, 01:47:23 pm »
That's right, it's hard to say, that's why I asked by showing a board by Steve
he told (post #2)
« Last Edit: July 14, 2019, 01:49:34 pm by kagliostro »
Offline jim
« Reply #11 on: July 14, 2019, 01:58:35 pm »
So the point is if one is using many fat lead  components like cc resistors and orange drops rather than metal film resistors, Mallory or Xicon caps then eyelet construction should be specified rather than turret.Jim
Offline Tony Bones
  • Thread Killer
« Reply #12 on: July 14, 2019, 09:40:21 pm »
Or, if you're laying out the board from scratch and it's not super cramped, then just use more turrets and jumper them together. Often looks neater that way too.
Look, for example, at Sluckey's AC15 layout http://sluckeyamps.com/VAC15/ac15.htm. There are a lot of components on that board, but Steve laid it out so that most of the components are parallel, generally no more than two leads per turret, but used a lot of jumpers. The alternative would have been to have many components going in all different directions in order to minimize he number of turrets. I think it looks better the way Steve did it.
« Last Edit: July 14, 2019, 09:47:32 pm by Tony Bones »
