August 29, 2026, 04:59:28 pm
Hoffman Amps Forum image Author Topic: Gibson 1966 GA 55 RVT  (Read 14220 times)
Offline Big chief
« on: September 09, 2019, 11:19:50 am »
Purchased chassis of Gibson GA 55RVT sounds fairly well need some TLC
Need to know Resistor SK 250 10% that is all it shows What ohm is it as the end is broken off and can not get a reading  Please help
Re: Gibson 1966 GA 55 RVT
« Reply #1 on: September 09, 2019, 12:15:38 pm »
Pictures. Schematic.
« Reply #2 on: September 09, 2019, 12:16:55 pm »
schematic to reference would be nice... or a least a link to one.
« Reply #3 on: September 09, 2019, 01:25:03 pm »
Here's a plan with that number on it, but I don't see any SK, 250, or 10%. Gibson was known to change plans on a whim and never tell anybody.
Offline Big chief
« Reply #4 on: September 09, 2019, 06:34:27 pm »
Please see photo
« Reply #5 on: September 09, 2019, 07:01:04 pm »
I believe that says 3K. Not SK.
Offline Big chief
« Reply #6 on: September 09, 2019, 07:07:36 pm »
So replace with 3k resistor
Many thanks
« Reply #7 on: September 09, 2019, 07:10:30 pm »
You have two identical parts. I wonder what the other one measures.   :think1:
Offline Big chief
« Reply #8 on: September 09, 2019, 08:09:38 pm »
37.42 ohm with fluke volt meter
« Reply #9 on: September 09, 2019, 09:54:00 pm »
a little larger copy and perhaps a bit more legible.
-pete
EDIT: perhaps not!
« Reply #10 on: September 09, 2019, 10:31:42 pm »
i believe that the two white parts are marked:
SK
250
10%
are those the parts you're asking about?
Offline Big chief
« Reply #11 on: September 10, 2019, 05:20:32 am »
Yes trying to find what they are and what size they are so I can replace them any help would be great
« Reply #12 on: September 10, 2019, 08:01:36 am »
Disconnect the good one and measure it out of circuit.
Offline bmccowan
  • Better builder than player
« Reply #13 on: September 10, 2019, 09:04:05 am »
might those be 250 pf capacitors? - I have removed similar looking & sized caps marked HI-K 250mmf 20%
Mac
John Prine
« Reply #14 on: September 10, 2019, 10:52:19 am »
that's what i was thinking.
« Reply #15 on: September 10, 2019, 10:52:33 am »
Looks more like a cap to me.  :dontknow:
Measure it for capacitance.
Figure out what they are connected to in the circuit and that should tell you if their resistors or caps.
Offline Big chief
« Reply #16 on: September 10, 2019, 11:37:41 am »
As soon as I get home I’ll remove the good one and measure.
I have spent hours tracing the wires from Vi V2 V3 looking at the
Schematic can not locate any info on these components
Maybe I just don’t understand  Thanks for all your help
« Reply #17 on: September 10, 2019, 01:34:11 pm »
I don't see anything on the schematic with a value of 250, but that's not unusual for a Gibson amp. That trim pot should be in the tremolo driver circuit. I would guess that the white component close to the trim pot is also in the tremolo circuit. If you can determine that either of those connects to a tube pin that would be a big clue.
Offline bmccowan
« Reply #18 on: September 10, 2019, 01:50:31 pm »
C4 and C23 are both 250p on the schematic. C26 looks like 210p?
Agree that knowing what they are connected to will help a lot. It's very hard to tell on the photo.
Mac
John Prine
« Reply #19 on: September 10, 2019, 02:02:08 pm »
Don't know how I missed those. C26 may be a 270p. That's a more common value. C4 and C23 should be easy to trace/identify since one end of each goes directly to a treble pot and nothing else.
Offline Big chief
« Reply #20 on: September 10, 2019, 02:56:56 pm »
Disconnected component at top of photo meter set 20nf reading0.22 200nf 0.12
2000pf meter not stable
Disconnected component bottom of photo meter set 20nf reading 80 200nf 00.4
Wire from v3 pin 6 goes to right side of component v2 pin 5 goes to left of component
Is trem pot bias for 6l6. What ever I need will order from this web site
« Reply #21 on: September 10, 2019, 03:37:42 pm »
Are you sure? That makes no sense.
The trim pot is for the tremolo circuit. Look at the schematic.
Offline Big chief
« Reply #22 on: September 10, 2019, 04:26:32 pm »
see photo
Offline Big chief
« Reply #23 on: September 10, 2019, 04:30:04 pm »
I'm sorry did not know that trem pot was for tremola had never seen one
Please view photo of wiring from tubes
« Reply #24 on: September 10, 2019, 06:23:05 pm »
Finally got around to the schematics
Gibson has out-done itself  :laugh:  :think1:
Offline bmccowan
« Reply #25 on: September 10, 2019, 06:39:05 pm »
Chief,
As Sluckey suggests, please check those connection points again. What you state would not be right, and it does not look that way in the photo to me, but the photo is still hard to see. For example pin 6 on V3 appears to be a blue wire that goes heads outside the chassis, which is consistent with the schematic.
Also - I think you probably need to suspect that previous work has been done and that it may have been done with mistakes/mods - some of the work looks a little suspect, even for Gibson. :icon_biggrin:
Mac
John Prine
« Reply #26 on: September 10, 2019, 08:30:20 pm »
You need to practice counting tube pins.
Offline Big chief
« Reply #27 on: September 10, 2019, 09:34:28 pm »
As the last photo shows I have put orange dot on wires
V3 pin 7 green wire to right side of component looking from back of amp
V2 pin 5 dark blue  wire to left side of component
Eyes must have been crossed
Do you think still 250 pf capacitor
Thanks for all your help I’m still learning
Offline bmccowan
« Reply #28 on: September 11, 2019, 05:19:24 am »
Do you think still 250 pf capacitor?
Yes, that's what I think they are. Others may differ.
Some additional things to consider. Given Gibson's tendency to constantly change circuits I snooped around on the web early this morning. I read that Gibson used the GA-45RVT circuit in some GA-55RVT models. I found that schematic which is much clearer than the GA-55 schematic - its attached. It includes those two capacitors (C41 & C43) but this time with a value of 500pf. This would also be typical of Gibson to change spec on small capacitors.
I'm also including a link to an article from a student who repaired and modded a 45 for a class project (i clearly wasted my time studying public policy!) It includes photos of the amp showing teal colored small caps in that location, and a schematic with some mods he did. Not vouching for what was done, but a lot of folks remove some of the extra circuit complications that Gibson added to 1960s amps.
https://courses.physics.illinois.edu/phys406/sp2017/Student_Projects/Fall02/MHerrmann/Mark_Herrmann_P398EMI_Final_Report.pdf
BTW, you are not likely to find 250pf caps that look like those today. Ceramic disc or silver mica are the probable choices.
« Last Edit: September 11, 2019, 05:27:51 am by bmccowan »
Mac
John Prine
Offline Big chief
« Reply #29 on: September 11, 2019, 10:10:28 am »
Thanks so much for the new information it was a big help
Many thanks to all the professional people that have helped me solve this problem
Offline Big chief
« Reply #30 on: October 04, 2019, 05:45:26 pm »
Need help to hook up reverb tank as the amp has only 1 RCA socket for reverb tank
schematic shows 2 wires from tank I do not understand where to hook up second wire
Please help
« Reply #31 on: October 04, 2019, 06:42:18 pm »
The tank input cable probably connects directly to the reverb transformer on the outside of the chassis. Probably solder connection.
« Reply #32 on: October 04, 2019, 06:43:27 pm »
look at the schematic, reverb section, top wire is a shielded cable (guessing rca jack)
the bottom wire shows a << for an unshielded wire, follow that line back to the parts n see if there's a stray wire or a broken off stub of wire
« Reply #33 on: October 04, 2019, 07:33:42 pm »
Yep. Except they used crimp stake-on connectors. See pic...
Offline Big chief
« Reply #34 on: October 04, 2019, 09:53:06 pm »
Again many thanks made wire from transformer to input reverb
Works fine
THANKS
