September 15, 2026, 03:25:03 pm
Hoffman Amps Forum image Author Topic: Big Problem with AC15C1  (Read 6099 times)
Offline rczcustom
« on: November 05, 2019, 02:18:30 pm »
Why it sound like this?? one audio is with all down and the other one is when I turn up a little bit the volume
https://drive.google.com/open?id=1w6gaIoH4uef95IBWgjxBovlIjzvoNbch
https://drive.google.com/open?id=1w8asmeUUDu3zUF9pvmLgQidHs2TLnduw
Re: Big Problem with AC15C1
« Reply #1 on: November 05, 2019, 03:13:49 pm »
this one of the re-issue amps, build with a pcb?  If so, there's your answer 80%
Offline rczcustom
« Reply #2 on: November 05, 2019, 04:06:58 pm »
Is ac15c1 from 2016
« Reply #3 on: November 05, 2019, 04:14:45 pm »
Unless you've logged some time troubleshooting pcb circuits, you are probably better off taking it to an amp tech.  I've turned down most of the pcb re-issue amps because they are a PITA, for little satisfaction  :icon_biggrin:
Offline rczcustom
« Reply #4 on: November 05, 2019, 04:20:13 pm »
I think the problem is one EL84 that sound something inside
« Reply #5 on: November 05, 2019, 05:28:10 pm »
probably, I've fixed 2 ac30c?, both had major smoke damage in the PA section  :icon_biggrin:
« Reply #6 on: November 05, 2019, 05:40:26 pm »
You said it's a 2016 model? So, 3 year old power tubes, you play a lot? Loud?
Could just be a bad EL84?
It's a cathode bias power section, no bias adjustment needed for new tubes, pop in a new matched set of EL84's and see if that fixes it.
If not, you'll need new tubes some day, so not a waste of money.
« Reply #7 on: November 05, 2019, 05:41:29 pm »
only schematic I've found is here, older than yours
https://el34world.com/charts/Schematics/files/Vox/Vox_ac15_reissue.pdf
look for crispy, discolored, burnt around the PA tubes, especially the connectors, cn2 & 3 in the schematic.  the burnt typically leads to taking out the board, which leads to bad solder joints, cracked foil n such.
before all that a complete list of current VDC's from all the tubes n PS comes in handy
Offline rczcustom
« Reply #8 on: November 05, 2019, 06:06:14 pm »
Now it's sound okey, I move the EL84 a little bit and it's work fine!
It's Weird
Offline Pietro
  • I love everything thats vintage. Even my mom!
« Reply #9 on: November 07, 2019, 12:46:19 pm »
well...then it won.t be fine for long.
I love everything that's vintage. Even my mom!
Offline texwest
« Reply #10 on: November 07, 2019, 09:06:50 pm »
If moving the tube made it work,  then I would replace the tubes and touch up the solder on the tube sockets.  But if you have never been inside a tube amp don't do it yourself.  There are dangerous voltages in there even when it is off and unplugged.  Take it to a qualified amp tech.
