September 08, 2026, 06:25:31 pm
Hoffman Amps Forum image Author Topic: What is this?  (Read 4931 times)
Offline yorgle
What is this?
« on: January 08, 2020, 01:46:18 pm »
I found this in a box of misc tubes that I purchased from a local antiques store.  It's solid aluminum and has "sockets" to fit both 7 and 9 pin miniature tubes.  Being solid, its obviously not intended to be used in a circuit.  It has "La Point Industries, Inc. Rockville, Conn." stamped on the flange.  Something to straighten tube pins?  A place to store extra tubes inside a radio/amp?  Any old timers here recognize it?
Re: What is this?
« Reply #2 on: January 08, 2020, 08:59:55 pm »
Re: What is this?
« Reply #3 on: January 08, 2020, 10:13:18 pm »
From reviews:
"the last pin straightener you'll ever need."
I have never seen one of these worn-out. Even the cheap zinc ones. yorgle's tool screws to the bench so you never lose it.
Obviously the vast majority of these were thrown-out when the daughters cleared-out dad's shop and nobody knew what it was.
Re: What is this?
« Reply #4 on: February 14, 2020, 11:28:08 pm »
The pin straightener below was left behind in a tube caddy I got.  The 9-pin side is shown below and there's a 7-pin socket on the opposite side.
The bell-shape is a suction cup to pull tubes from their sockets without burning your mitts.  Squeezing near the top releases the tube.
