September 19, 2026, 02:18:25 am
Hoffman Amps Forum image Author Topic: Pedal Power Supply DIY?  (Read 9932 times)
Offline John R
« on: January 23, 2020, 02:13:34 pm »
Hi - This is a project I have wanted to do for awhile - make a simple-ish 9V string with maybe 6 outputs, using a printer power supply?
   I am sort-of adept at figuring this stuff out, but still a learning amateur for sure.
   I did see something on one of the DIY blog sites, but in was a 120vac line unit as I recall.
   What I'd like to do is use as-new 18vac 6A (I think it is vac, not vdc, need to dig it out) HP printer supply pack  and I assume a string of Voltage regulars with r/c filters - ? I believe AES has VR's for sale.
   Anyone have ideas and suggestions?  I think this could be a common use for ps's sitting as printers are seeing less use.  I don't have or know how to use schematic programs but can draw and photo/upload schematic/layout ideas.  Maybe this has been done here already?
   Thanks for reading and any info's and  :help:
Re: Pedal Power Supply DIY?
« Reply #1 on: January 23, 2020, 03:13:07 pm »
Here's what I built for a pedal board...
Offline Joel
« Reply #2 on: January 29, 2020, 09:24:13 pm »
I made a 12 legged spider transformer with a regulator for each leg using this website as a reference; http://geofex.com/article_folders/oldspyder/oldspyder.htm
The mouth of a happy man is filled with beer  - Egyptian Proverb
Offline John R
« Reply #3 on: February 02, 2020, 11:57:27 am »
Thank you both :icon_biggrin:, I'll check out the link, and copy your schematic SLuckey. I have only a couple pedals now and don't chain anything but would like a univibe/phase 100 or such and maybe others at used prices, so thus a need for ps.
Take care everyone, and thanks for so much great info's here, I need to buy parts to pay back for all the learning. Have a few projects trying to decide where to take them.
JR
« Last Edit: February 02, 2020, 12:24:08 pm by John R »
Offline John R
« Reply #4 on: February 02, 2020, 12:19:20 pm »
OK Had a look and Joel's spider looks like something I heard about and a pedal parts supplier was selling tiny tx's for something like this I assume.
Thanks Steve for this design it looks really cool/elegant.  I do like this as it looks like less parts. I'll look to mouser etc and see if I can figure a layout and the correct parts and post a list and drawing and maybe you can confirm I'm on the right track.
Never done a red led(I assume the arrow symbols are light wave emission for red indicator :l2:-still learning the basics...The adjustability per 500R is cool for adding/subtracting loads using single source power point.
I'd make this on a alum sheet deck with wood frame surround and bottom and shielded interior.  Thanks again.
Offline John R
« Reply #5 on: February 11, 2020, 09:32:29 pm »
Just to follow up and not leave this hanging - I have looked for V-Regs and studied again the blog at 'Instructables' ; have a good idea how to do this, but prefer to batch parts together in one order and shipping, and I get by with wall warts ok. I tried finding the VR and 500R trimmer etc per mouser, on SLuckeys schematic, and NLA but others are similar, so I assume it is generic to some degree.
Thank you all for the suggestions and if/when I do this project I'll add to this some pictures.  I am working first on tube amp projects, and this may be more hassle than it is worth.
Be well everyone, and thanks again.
« Reply #6 on: February 12, 2020, 02:06:16 am »
The LM123 is probably obsolete but it was very popular in '70s era TTL radar systems. I chose that because I had access to plenty of them. It's a nice heavy duty TO-3 case three terminal 5V @ 3A VR. I'm sure there are plenty of modern 3A VRs available. 3 amps will power a lot of 9V pedals! I use a 12VAC wall wart to supply my 8 pedals plus a cry baby. The LM123 doesn't even get warm. You can see it mounted on the back of my pedal board. I never saw a failed LM123.
     http://www.ti.com/lit/ds/snvs757b/snvs757b.pdf
Offline John R
« Reply #7 on: February 12, 2020, 03:20:06 am »
 Thanks Steve.  The sites I looked at gave sub's similar in the metal case, def heavy duty looking and price was somewhere at $80 I think. The smaller type are $3 which are fine inside a casework.
I just like the idea of using up stuff that is good and sitting around.  The v-r's aren't easy to get around here as radio shack is gone now...used to be 2 stores here.
 Appreciate your help and great Visio work and blogs you offer to public viewing, beautiful work for sure.
« Reply #8 on: February 12, 2020, 03:24:58 pm »
You need to shop on eBay for LM123 or LM323. Plenty available in the US for $5 to $10. And you can get them for $2 if you want to buy from China.
« Reply #10 on: March 26, 2020, 09:57:22 am »
have a look at these parts.
