September 15, 2026, 03:32:25 am
Hoffman Amps Forum image Author Topic: 1.5k resistors for 4 power tubes  (Read 15228 times)
Offline sjwood3
  • Get to tha choppa!
« on: April 23, 2020, 08:32:15 pm »
This may seem simple to some of the experts.  I'm building a Hoffman Twin Reverb with 4 power tubes instead of two.  No rectifier.  The picture I've included is of the Ab763 two channel power tube section.  I understand how to jumper the two additional tubes into the mix, but do I need the 1.5k resistor in the same position on the V8 and V10 power tubes?
« Last Edit: May 06, 2020, 09:23:12 pm by sjwood3 »
SW
Re: 1.5k resistors for 4 power tubes
« Reply #1 on: April 23, 2020, 08:46:10 pm »
Yes. Then just connect pin 6 of the two tubes together.
Offline sjwood3
« Reply #2 on: April 23, 2020, 09:03:49 pm »
To clarify, jumper pins 6 on v7 to v8 , then separately jumper pin 6 on v9 and v10?  This is assuming I'm following the Hoffman advise on jumpering the two new tubes into the system.
SW
« Reply #3 on: April 23, 2020, 09:15:26 pm »
That's correct. But be careful. It's easy to get mixed up with this.
Offline sjwood3
« Reply #4 on: April 23, 2020, 09:18:15 pm »
Of course.  I really appreciate your feedback.   Check and double check!
SW
« Reply #5 on: April 23, 2020, 09:32:24 pm »
Same thing applies for each 3W 470R screen grid resistor going to pin 4 (between Pin 1 and Pin 4). The opposite pairs can be linked by a single wire between Pin 1 on each pair, with only one of each pair needing another wire going to the screen supply node on the main board.
« Reply #6 on: April 23, 2020, 10:01:23 pm »
He's following Hoffman's layout... All screen resistors are on the board and 1.5K stoppers are mounted between pins 5 and 6. And pin 1 is jumpered to pin 8. I fear the Fender stuff may just add a bit of confusion.
Offline 2deaf
  • Now too deaf for 100 watts
« Reply #7 on: April 23, 2020, 10:11:08 pm »
Sorry.  I'll remove it.
Offline sjwood3
« Reply #8 on: April 23, 2020, 11:27:55 pm »
So is this alluding to a fender layout as well or the Hoffman layout?
SW
« Reply #9 on: April 23, 2020, 11:47:21 pm »
The red circled bit (attached) - from the Hoffman layout you posted earlier
Offline sjwood3
« Reply #10 on: April 23, 2020, 11:59:25 pm »
I see.  I'm not using the short board.  So the one above it is my point of reference.  Sorry for the confusion. I also appreciate your responses. This is making me think.  Dont worry, I wont turn it on unless I know it's right.
SW
« Reply #11 on: April 24, 2020, 12:03:23 am »
I see.  I'm not using the short board.  ...
Even if you're not using the short board, each output tube really has to have it's own screen resistor (to prevent screen grid failure under heavy signal conditions). So you might as well mount them like that (seeing as how you've got 4 output tubes'n'all) - unless your'e going to somehow mount all 4 screen grid resistors on the main board (which is inferior to mounting them at the tube socket pins - from an RF interference point of view)
« Last Edit: April 24, 2020, 12:08:11 am by tubeswell »
Offline 2deaf
« Reply #12 on: April 24, 2020, 12:40:02 am »
After I made my mistake and removed it, I read the first post carefully and looked at the Hoffman build stuff.  The board for 4 output tubes has four screen resistors on it, so all the OP needed was the info on connecting the grids.
Offline sjwood3
« Reply #13 on: April 24, 2020, 01:10:06 am »
Yes.  RF superiority aside (which I'd prefer), that is my question.  I'm trying to keep this build as simple as possible according to Hoffman's specs. Mods can be made later.  I love these responses.  Really have my gears turning!
« Last Edit: April 24, 2020, 01:14:08 am by sjwood3 »
SW
Offline Bantam
  • I love Tube amps,so lid state amps,
« Reply #14 on: April 24, 2020, 12:13:44 pm »
Every twin I've ever come across is 4 power tubes already... Is this like an old one with two that's being built up to 4? I've obviously missed something.
Offline sjwood3
« Reply #15 on: April 24, 2020, 12:17:45 pm »
It's a quad reverb chassis, 4 Power tubes already there.
SW
« Reply #16 on: April 24, 2020, 12:19:04 pm »
Take a look at Hoffman's AB763 documents. Should cover everything you're missing.
« Reply #17 on: April 24, 2020, 12:26:00 pm »
Yeah- different AB763 layout options in Doug’s pictures. The layout diagrams show two tubes with choices for grid resistor layouts on sockets or boards, and the notes also discuss 4 tubes.
So this is the Quad Reverb rebuild from that other thread? Now I see where you’re coming from.
Offline sjwood3
« Reply #18 on: April 24, 2020, 12:36:19 pm »
Yes this is the rebuild that I was taking suggestions on from the other thread.   Sorry I started a new thread!  I'll keep it all to this post.   I can clearly see the layout difference between the short and long boards now.  I'm following the layouts and schematics, but fully understanding how and why it's all happening is crucial for me as well. That's part of the fun.
With regards to the pin 6 connections for each pair you (sluckey) mentioned above, why is this not covered in the image explanation for the difference between 2 tube and 4 tube (Hoffman Ab763 2 Channel) amps?  Screen shot of the section is what I'm talking about.
SW
« Reply #19 on: April 24, 2020, 12:44:22 pm »
:dontknow:  Only the Doug knows why???
But I can tell you what will happen if you don't make that connection.   :icon_biggrin:
Offline sjwood3
« Reply #20 on: April 24, 2020, 12:47:00 pm »
I bet!  I really appreciate everyone's insight.  It's been super helpful.  My board arrives tomorrow.   I'll have more questions I'm sure.
SW
Offline sjwood3
« Reply #21 on: April 25, 2020, 02:35:34 am »
Just want to make sure I followed what you said about jumpers on the power tubes; 3 to 3 on both pairs and 6 to 6 on both pairs.  Haven't hooked up the rest yet, those suckers were hard to make look good!   I installed the tubes while wiring those up so the pins would fit after I'm done.
« Last Edit: April 25, 2020, 02:55:47 am by sjwood3 »
SW
« Reply #22 on: April 25, 2020, 06:06:35 am »
That looks good. This should answer any other questions about output tube wiring that may come up...
« Reply #23 on: April 25, 2020, 06:40:45 am »
You will have to drill mounting holes in your board and the chassis. Do this BEFORE you do anything else to the board. Put the board inside the chassis and move it around slightly until you are satisfied with the position. Figure out where the mounting holes should be so as to not interfere with any existing screws (ie, transformer screws, cap pan screws, etc.) or any other hardware. I suggest 6 mounting holes and standoffs for a board this long.
Offline sjwood3
« Reply #24 on: April 25, 2020, 08:57:30 am »
Thanks!   :worthy1: That's a exacty how I envisioned the image I was looking for on Hoffmans site.   I've been following the order of operations he does with his builds.  So I am definitely waiting until my board arrives to move into all pin wiring that goes to the board.  Working on the basic infrastructure for now.  Input jacks are next.   Where in that chassis would you suggest to put a rotary switch for the addition taps on my OT transformer?  Its a 100W Hammond with two additional taps.  4/8/16. The switch is big and beefy, so either there isn't room for it or the taps wont reach it where there is a space for it in the chassis.   Last resort is not place the switch initially and create an exterior box for it later.
« Last Edit: April 25, 2020, 10:19:11 am by sjwood3 »
SW
« Reply #25 on: April 25, 2020, 11:50:04 am »
That impedance selector switch should be mounted very near the speaker jacks. Do not mount it on the preamp end of the chassis!
An alternative would be to use three speaker jacks, one for 4, another for 8, and the third for 16.
If you have the original back plate on the chassis, nothing you do will look very good.
Offline sjwood3
« Reply #26 on: April 25, 2020, 06:18:52 pm »
I found this link on Doug's site.  https://el34world.com/charts/CommonHookups.htm
At the very bottom there ins an older looking diagram of the same 4 power tube set up.   :BangHead:  :laugh:
SW
Offline sjwood3
« Reply #27 on: April 26, 2020, 02:01:15 pm »
Suppose I used a DP3T switch for impendance like in an Ampeg?  Would fit better somewhere.   :dontknow:  is that the same function, but a different shape?
SW
« Reply #28 on: April 26, 2020, 02:16:41 pm »
I would have to see the switch and/or a datasheet to answer that question.
Offline sjwood3
« Reply #29 on: April 26, 2020, 09:53:33 pm »
I'll leave that one for another day.  Likely I'm going to stick with the one output for now.   Once I find the best solution I'll tackle it as an additional modification.
Next question.   The filter caps.  My initial thought is to wire them in Series with 220K 3 watt Metal films.  I see that depending on the series or parallel arrangements in the "common hookups" section, there is a difference in Voltage.  I'm planning on using the doghouse to house the filter caps.    I can't figure how the B+ makes it from the power transformer to the standby switch by looking at the Hoffman layout.    I get the concept of how it should work.  Could be something simple, but I need some education on that.   The bias tap from the transformer  goes to the bias tap (right?), but where do the two red wires from the secondary go?  On a fender schematic, they go to the diodes  then out to the standby switch, but the bias circuit is on the board on the Hoffman, and I don't see an obvious place for the diodes.   Its a smidge confusing.  Maybe there is one, but I cant find a matching schematic to follow the Hoffman.  What am I missing?   Shouldn't there be 3 diodes off each red secondary line somewhere?   Links or answers welcome.
« Last Edit: April 27, 2020, 01:23:46 am by sjwood3 »
SW
« Reply #30 on: April 27, 2020, 01:37:06 am »
Looks like you need to ask Dougabout the diodes. He may have a small board for them. He may tell you to mount them on a small terminal strip. If you have the original diode board you could use that. Or you could make a simple turret board just for the diodes.
Just send him a pm.
Offline sjwood3
« Reply #31 on: April 27, 2020, 02:13:09 am »
Just send him a pm.
Sent him a message.   I have a feeling you're right.  Looking over the schematic, the diodes should be there as the obvious point of rectification.  I have them as well as included in the BOM.
WHat about this switch in the AC plug hold next to the fuse housing?  Could somehow shield the wires running to it?   Would running those connections by power tubes cause issues?
https://www.tubesandmore.com/products/switch-rotary-impedance-selector-replacement-marshall
SW
Offline sjwood3
« Reply #32 on: April 27, 2020, 03:26:27 am »
Just send him a pm.
I figured out the diode situation.  Ordered a board, I'll post pics once I get it wired up.
SW
« Reply #33 on: April 27, 2020, 07:04:21 am »
Looks like a good solution.
Did Hoffman already have a diode board?
Offline sjwood3
« Reply #34 on: April 27, 2020, 01:18:25 pm »
Yes, he has a bias board that includes a diode section for this type of set up.  I'll obviously leave the bias section alone.   I didn't think to look for it on the bias board.
How would the Negative feedback need to be connected to that type of ohm selector switch?
SW
« Reply #35 on: April 27, 2020, 01:26:33 pm »
The NFB should be connected directly to the 4Ω lead.
Offline sjwood3
« Reply #36 on: April 28, 2020, 12:03:56 am »
Here in the two power tube pic. There is a 1k/3W resistor.  The pic you posted was 10k/3W?  Is that a change I need to make or was that a typo?
« Last Edit: April 28, 2020, 12:07:54 am by sjwood3 »
SW
« Reply #37 on: April 28, 2020, 04:27:59 am »
1K/3W is the correct value for a twin reverb.
Offline sjwood3
Re:Twin Reverb Build
« Reply #38 on: April 29, 2020, 04:33:04 pm »
Here's progress.  Getting fun!  I grounded the preamp buss under the the standoff closest to the input Jack.   I'm going for a floating bus instead of a pot soldered bus.
SW
Offline sjwood3
« Reply #39 on: May 03, 2020, 05:58:13 pm »
Let's say I changed the value of C22 coming off the phase inverter to .001 from the suggested value of .01.  I ordered one short, but I have an extra .01/630V on hand.   What effects would that have?  Would  it be possibly detrimental to try?
SW
« Reply #40 on: May 03, 2020, 06:10:06 pm »
nope,  coupling caps, simple "look", the bigger the cap, the bigger the "bandwidth"
Offline sjwood3
« Reply #41 on: May 03, 2020, 06:33:15 pm »
My options are .1 or .001 /630V of the yellow Mallorys.   I could order another one...But I already have these parts.  Would .1 be to much?
« Last Edit: May 03, 2020, 06:36:44 pm by sjwood3 »
SW
« Reply #42 on: May 03, 2020, 06:47:55 pm »
Would .1 be to much
.1 is usually found more in HiFi, lets the bass through
.001 will tilt treble, so if you use 1 ea  :dontknow:  :icon_biggrin:
Offline sjwood3
« Reply #43 on: May 03, 2020, 08:08:07 pm »
Just found  this schematic.   I guess the .001 will do just fine since it's already there. Hoffman suggests .01 in his layout.
SW
