September 15, 2026, 06:52:26 am
Hoffman Amps Forum image Author Topic: AC15 passing signal when volume at zero (and a few other questions)  (Read 22309 times)
Offline liddokun
Hello,
I've finished an AC15 build, based on Sluckey's layout.
Most things have gone smoothly up until now.
The last kink I'm trying to iron out is two fold:
First, the volume pot on the normal EF86 channel. It passes signal even when the pot is set to zero. I thought it was a faulty pot at first, but tried several other pots and same issue.
Second, when both the top cut and volume (ef86 normal channel) are set to zero, there is a buzz, almost sounds like 120hz.  As soon as either the volume or top cut pot is turned up, the buzz goes away immediately.  I'm not sure if this is related to the first problem.
I've taken some voltages at the tubes
V1 (12ax7 trem/vib preamp)
1-67v
3-3v
6-190v
8-3v
V2 (ef86 normal channel preamp)
1-111v
6-107v
V4 (12au7 modulator)
1-67v
3-3v
6-67v
8-3v
V5 (phase inverter)
1-251v
3-63v
8-63v
6-238v
V6 (12ax7 PI/oscillator)
1-128v
6-190v
V7 (el84)
3-11v
7-341v
9-342v
V8 (el84)
save as V8
I was using Sluckey's schematic as reference, with his listed voltage measurements, I can see it's off, but not by much.  I realize there may be sevaral issues at play here.
« Last Edit: April 26, 2020, 02:45:01 am by liddokun »
Offline Latole
Re: AC15 passing signal when volume at zero (and a few other questions)
« Reply #1 on: April 26, 2020, 02:58:17 am »
Check solder to ground
Show schematic or it is like any Vox AC15 ?
You do a nice job.
« Last Edit: April 26, 2020, 03:37:11 am by Latole »
Offline liddokun
« Reply #2 on: April 26, 2020, 03:12:05 am »
I used Sluckey's layout/schematic, which can be found here
https://sluckeyamps.com/VAC15/Vox_AC15.pdf
Offline Latole
« Reply #3 on: April 26, 2020, 03:30:13 am »
Thank you ?
Update; low pot value= low output power. It is not your issue.
How much chan Normal volume lets signal passed ? 1/10, 6/10 ?
Reheat some solders.
« Last Edit: April 26, 2020, 03:37:44 am by Latole »
« Reply #4 on: April 26, 2020, 04:06:12 am »
I suggest to try revising connection of the 0V terminal of both vol controls to the 0V turret of the LTP tail resistor R38.
That arrangement seems to better conform to Merlin’s ‘multiple star ground’ system, see Fig 15.14 http://www.valvewizard.co.uk/Grounding.pdf
« Last Edit: April 26, 2020, 04:11:49 am by pdf64 »
Offline liddokun
« Reply #5 on: April 26, 2020, 04:25:39 pm »
I'll give that a shot and see how it goes
Offline liddokun
« Reply #6 on: April 26, 2020, 06:00:42 pm »
I gave that a shot, it doesn't make any discernible difference to the initial issue of the normal channel passing signal still.
The vibrato/tremolo channel does behave as expected and passes no signal at zero.
« Reply #7 on: April 26, 2020, 06:17:01 pm »
Use a gator clip lead to ground the point in the pic. Does that totally kill the normal channel?
If so, ground the wiper of the pot with the gator clip lead. Does that totally kill the normal channel?
Only thing between the pot and that turret is a wire.
Offline liddokun
« Reply #8 on: April 26, 2020, 07:49:26 pm »
Grounding that point in the picture does not totally kill the normal channel.  There's no preceivable difference when I aligator clip that point to ground.  Grounding the wiper of the pot comes up with the same result.
« Reply #9 on: April 26, 2020, 08:01:52 pm »
Hmm. OK... Disconnect that white wire from the turret in the pic. Does that kill the normal channel?
Offline liddokun
« Reply #10 on: April 26, 2020, 08:10:18 pm »
When I disconnect it, I get a louder signal and a ton of hum
« Reply #11 on: April 26, 2020, 08:13:16 pm »
OK, with the white wire still disconnected, ground the turret in the pic. Does this kill the normal channel?
Offline liddokun
« Reply #12 on: April 26, 2020, 08:22:32 pm »
Disconnecting the wire and grounding the turret does not kill the normal channel.  I get the same amount of volume as before (as described in my oringal post).
« Reply #13 on: April 26, 2020, 08:35:32 pm »
Beginning to look like one or both of the 8µF filter caps are either not grounded or are just bad.
First use your gator clip to ground the negative lead of each cap, one at a time. Any joy?
Second use two gator clip leads to connect another filter cap parallel to a 8µF cap, one at a time. Any joy?
edit... solder joints on the negative leads of both those 8µF caps look suspicious.
« Last Edit: April 26, 2020, 08:39:50 pm by sluckey »
Offline liddokun
« Reply #14 on: April 26, 2020, 08:40:16 pm »
Should I be doing this with the white wire disconnected?
« Reply #15 on: April 26, 2020, 08:41:27 pm »
You can reconnect the white wire.
Offline liddokun
« Reply #16 on: April 26, 2020, 09:13:53 pm »
Neither grounding each 8uF negative lead, nor strapping another filter capacitor parallel makes a difference.
edit: I also went ahead and reflowed some solder onto those suspicious 8uf negative joints.
I'll try to source some brand new 8uF caps tomorrow, and see if swapping those out makes a difference.
« Last Edit: April 26, 2020, 09:21:36 pm by liddokun »
« Reply #17 on: April 27, 2020, 06:09:10 am »
OK, it was worth a try  :think1:
Did it bring any improvement to
Offline liddokun
« Reply #18 on: April 27, 2020, 01:52:36 pm »
No, unfortunately not.  I'm going to try replacing the 8uf filter caps, and reflow the solder on all my wiring.
There's a massive build thread of this same circuit that I found here https://el34world.com/Forum/index.php?topic=24337.0 .  This user seemed to have had some similar issues to myself as well, I'm going to scour through and see what I can find here as well.
Offline terminalgs
« Reply #19 on: April 27, 2020, 02:15:28 pm »
If the amp is passing audio signal when volume pot is turned to "zero", it is likely the filter cap for the preamp is effectively "not there" (bad, cap, bad solder, bad wiring, etc...)
especially if as you turn the knob up, audio decreases slightly and possibly goes silent and then as you continue to turn it up, audio reappears and gets louder like you would expect.
What happens is the pot is doing it's job., no signal reaches the next stage via the next stage grid input, BUT it does reach the plate of the next stage by "escaping" up past V1's plate resistor  and finding its way to V2's plate via V2's plate resistor.
the escaping V1 audio signal is out of phase with what the V2 plate produces.  That is why it goes silent around 0.5-1 volume when the two signals completely cancel each other out.
Also, that escaping V1 audio is attenuated by the voltage divider that is the V1 plate resistor and the last dropping resistor in the B+ chain, so if the plate R is 100K and the dropping resistor is 10K then is about a ~90% signal voltage cut.  That is why you get that phase cancellation notch of near silence around 5-10% volume pot throw.
If you have three or more triodes in a series (signal wise) all sharing the same B+ node, you can get some weird feedback as later stages feed each stages. Also a CF stage will put audio signal on its plate b/c that dropping resistor is not effectively the CF stage plate resistor.
Offline liddokun
« Reply #20 on: April 27, 2020, 04:40:56 pm »
Ah, got it.  So I replaced the filter cap with a new one, I'm still getting this issue.  Reflowed all the solder joints, in addition to the new filter cap.  Any other suggestions as to where I need to look to address this?
Offline terminalgs
« Reply #21 on: April 27, 2020, 07:18:21 pm »
I'm guess you don't have an o-scope....
double check to make sure you have 0-ohm between filter cap (-), the ground on the pot, and the ground under your 1st reservoir/filter cap.
beyond that, I'd suspect a wiring error somewhere...
« Reply #22 on: April 27, 2020, 08:15:02 pm »
You have eliminated all the logical gremlins. I too expect a wiring error.
Offline liddokun
« Reply #23 on: April 27, 2020, 08:31:26 pm »
Unfortunately I have no access to a scope.
My meter reads .02 when I measure between those 3 points.
Offline Latole
« Reply #24 on: April 28, 2020, 03:32:24 am »
I agree,
 liddokum, double check wiring.
If you build or fix amps, a scope is a must. You can find good one for $150 second hand, a audio signal generator too.
Most difficult is to know how to use them properly.
Good luck,
Offline d95err
« Reply #25 on: April 28, 2020, 04:09:14 am »
I noticed that the schematic shows very small filter cap values.
I’d start by increasing those, especially for the preamp, to e.g. 22uF.
You could test by temporarily parallelling bigger caps to the preamp filter stages with alligator clips.
Offline Latole
« Reply #26 on: April 28, 2020, 04:15:03 am »
Original AC15 use 16 mfd.
OP follow Sluckey layout, I'm sure Sluckey built this amp and it work with low filter caps
« Reply #27 on: April 28, 2020, 04:40:43 am »
No, 8µF is the original value for this amp. Small size is NOT the problem. There have been at least a dozen successful builds of this amp using this layout. Probably other builds that I don't know about.
Offline Latole
« Reply #28 on: April 28, 2020, 05:13:35 am »
I see those values what it look a old schematic on your link
« Reply #30 on: April 28, 2020, 10:19:05 am »
If you look closely you will see five filter caps on that old schematic... two 16s, two 8s and one 32. They are scattered about, but not too difficult to find.
Offline Latole
« Reply #31 on: April 28, 2020, 10:25:03 am »
You are right  :BangHead:
Offline liddokun
« Reply #32 on: April 28, 2020, 04:35:29 pm »
Thanks for all the suggestions so far.
As mentioned, lots of successful builds with this layout, I probably made a wiring issue somewhere along the line.
Going to go through and double check everything.
Offline cboysen
« Reply #33 on: April 28, 2020, 04:51:24 pm »
120hz hum, sound af zero volume..
I would have expected a faulty preamp filter cap (c26). That being said, the  500k volume pot in conjuction with the 0.1uF(c27) capacitor to the PI, could be acting as a parasitic antenna, picking up stray capacitance from the nearby area, when the impedance is high enough (500k).
You could try to lift the cap from the turrets, and move it around (carefully), to see if the sound changed.
Also, just for good measure (pun intended), do you see a voltage on pin 1 of the volume pot, when it's turned down? If so, c12 might be leaking dc.
While you have the multi meter pointed at the pot, make sure the pot reads zero ohm across pin 2 and 3 when the volume is turned down, otherwise sound will creep through.
Hope you sort it out
Kind regards, Christian
« Last Edit: April 28, 2020, 04:56:40 pm by cboysen »
Offline liddokun
« Reply #34 on: April 28, 2020, 05:08:08 pm »
Sluckey suspected a faulty filter cap too, and suggested this, and I replaced the cap with brand new ones, to no avail.  I've also tried moving the cap around with longer leads.
Lastly, 0 volts on all 3 pins, unfortunately.  I was hoping it would have been something like a leaky cap.
Alas, I will have to go through all my wiring.  The amp isn't that neatly wired so maybe it's a good thing, anyways that I'm going through it all.
Offline Latole
« Reply #35 on: April 28, 2020, 05:55:10 pm »
I built a lot of electronic gear. Each time they did not work on first power ON, is was one of my mistake in wiring.
Good luck.
Offline liddokun
« Reply #36 on: May 17, 2020, 10:31:04 pm »
Sooooo.....
I left this alone for a week or two and came back to it.
Reworked all the solder joints, went through the layout with a highlighter and double checked everthing.  I damn near redid every off board wire.
I've managed to solve the main issue of signal passing through when the volume is at zero.
I'm just about at a point where I'm happy with this, but I haven't been able to resolve the "buzz when both top cut and volume at zero" problem.  If both volume pots AND the top cut are at zero, I get a pretty loud hum, I think it's 120hz.  When I turn any of those controls up, the there's a faint pop and the hum goes away.
Very peculiarly, if I take an aligator clip and clip it to one of the turrets circled in red in the attached photo, the hum disappears.  The aligator lead is not connected to anything on the other end.  Clipping the aligator lead to the other end (potentiometer terminal) does not have the same behaviour.
Offline Latole
« Reply #37 on: May 18, 2020, 02:51:35 am »
Solder the alligator clip there and put electrical tape on other end AhAh !
Where is my red arrow, this is the turrets you are talking about ?
What are the 2 black wires ? Power transformer ? Il yes, IMO these black wire are to close from the 2 white wires from the turret.
I'll put the 2 whites wire under the black ones, close to the chassis.
I don't like your lead dress. All whites wires I see must be run close to the chassis.
Capture d’écran, le 2020-05-18 à 03.43.35 by Louis LAFLEUR, sur Flickr
« Last Edit: May 18, 2020, 02:55:59 am by Latole »
Offline liddokun
« Reply #38 on: May 18, 2020, 02:56:32 am »
Those two black wires are the choke wires.
I've relocated those wires though, they no longer come into the chassis there.
I'll snap a few photos of my redone wiring and post.
Offline Latole
« Reply #39 on: May 18, 2020, 03:02:02 am »
All blue wires must cross other blues wire in 90 degrees angle and close to chassis, never close in parallel to each other
« Reply #40 on: May 18, 2020, 07:30:11 am »
Can you try something like this shield (from Larry Amps) ?
Offline liddokun
« Reply #41 on: May 18, 2020, 02:45:36 pm »
Franco,
What would the shield do?  Also, where would I be placing it?
Here's some updated photos of my wiring, after I reworked a bunch of it to be cleaner/address the initial problem I posted about.
I've circled the turrets in red that can be aligator clipped to make the noise problem go away.
« Reply #42 on: May 18, 2020, 03:40:22 pm »
try moving the white wire closer to my red trace
also try and move the blue ef86 wire further away from  v5s green wire
you have tube shields on?
« Reply #43 on: May 18, 2020, 04:33:38 pm »
Connect the PI ground to the power ground. Any better?
« Reply #44 on: May 18, 2020, 04:55:35 pm »
What the shield do ? He shields ....
Larry used that trick probably because a nightmare incomed on his circuit/layout
Near for sure the shield was placed there empirically, with a try and repeat procedure, something like what you did with the gators
I was suggesting you to give a try to solve the problem putting on the layout a shield and moving it in a position that will give you positive feedback (if you are so lucky to find one)
Of course, before give a try to what Sluckey is suggesting, may be you can solve the problem without any shield (shield that isn't a for sure solution)
Offline liddokun
« Reply #45 on: May 18, 2020, 04:57:32 pm »
@shooter
Moved the white wire, as well as the blue wire on the ef86.  Had no changes to lowering the noise. Did notice that if the white wire is closer to the board, the hum gets louder.
All tubes are shielded.
@sluckey
Relocated the PI ground to the power ground.  I left the wire a little longer than usual, I noticed that the hum gets quieter depending on the position of the ground wire. But even when the ground wire is moved to a position where the hum is "barely audible", I still get the popping noise when I turn either of the top cut or volume controls up.
As I mentioned, clipping an aligator clip to any of the turrets I mentioned makes this hum go away completely.  I'm curious as to why this is.
« Reply #46 on: May 18, 2020, 05:30:14 pm »
might be acting as an RF shunt, same principle as only soldering one end of the shielding.
what is you're bias set at, how much current ?
Offline liddokun
« Reply #47 on: May 18, 2020, 10:03:18 pm »
What's the best way to measure this on a cathode biased circuit?  (please excuse my newbiness)
Offline nandrewjackson
« Reply #48 on: May 18, 2020, 10:13:58 pm »
I use these bias calculator websites
http://www.tedweber.com/webervst/tubes1/calcbias.htm
Or
https://robrobinette.com/Tube_Bias_Calculator.htm
Take your voltage readings, plug in the numbers.
« Reply #49 on: May 19, 2020, 01:46:03 am »
I remembered a small trick, something I've seen in some old amps
this can be a way to apply "Larry's" shield to your problem
is not a difficult thing to be tried
rolls a thin rigid wire tightly, without spaces, around the wires that go to those turrets, say for 5 - 10 cm
then join these thin rigid wires together (only one end) and connect this junction to ground
this will act as a small capacitor/shield which should discharge the disturbances picked up by the wires towards ground
does the noise decreases?
p.s.: This isn't the good example I would like to show you (the link is dead), however you can see what I mean
« Last Edit: May 19, 2020, 02:07:48 am by kagliostro »
