August 29, 2026, 04:58:58 pm
Hoffman Amps Forum image Author Topic: Vox AC4 Question(s)  (Read 73576 times)
Offline dwinstonwood
Re: Vox AC4 Question(s)
« Reply #200 on: June 06, 2020, 02:05:16 pm »
I'll get a faceplate made next. Maybe something like this.
« Reply #201 on: June 07, 2020, 11:03:43 am »
Late last night when it was really quiet, I noticed that if I let a B flat on the sixth fret of the low E string ring out it would start to oscillate as it faded out.
Well, I woke up bothered by this. So, I moved the ground wire from the EF86 pin 2 straight to the input jack ground (it was connected to the board at the negative end of the cathode cap, and shared a ground wire from there), and I replaced the 1Meg resistor coming off of B+ to pin 1 of the EF86 with the 5.6Meg resistor shown on the Vox schematic. I also rearranged the red wire from pin 6 so that it is tucked down and does not cross other wires.
This almost completely eliminated the wavering B flat, and the low level hum is reduced, too. Quiet enough that it I have to stop playing and listen for it. I might also add some adhesive foil under the top of the cabinet since the chassis is open on top.
Finally, I ordered some better tubes. I had grabbed the cheapest ones originally, but after some research I found that there are some better EF86's than the Electro Harmonix, and better EZ81's than the JJ.
« Reply #202 on: June 10, 2020, 11:20:45 am »
Grill cloth and custom faceplate installed. For a "first-time" amp build I'm happy with it.
I'd put my name on it. :icon_biggrin:
« Reply #203 on: June 10, 2020, 12:16:35 pm »
Looks Nice :thumbsup:
« Reply #204 on: June 10, 2020, 05:11:40 pm »
Very tidy
« Reply #205 on: June 10, 2020, 05:13:24 pm »
Thanks Franco!
Thanks tubeswell!
I still need to add the piping around the grill to cover up the small gaps.
I made some minor changes and the amp is now as good as I think I can get it.
I switched back to the 1Meg screen resistor from the 5.6Meg; I probably should have just left that alone. But, I have to tinker with stuff.
I did some research on filter capacitance and rectifier cathode coatings and I'm confident that I'm safe in these changes that I made. I was still getting some hum, so I bumped the first filter cap up from 30uf to 47uf, the second is the same at 30uf, and I replaced the third 8uf with a 10uf of the same brand as the others (F&T). I changed that one because I think I might have damaged it during soldering.
Now the amp is very quiet.
I replaced the JJ EZ81 and the Electro-Harmonix EF86 with a Tesla EZ81 and a Tung-Sol EF806 SG.
The amp now sounds better than ever, and it's very quiet. I like it a lot; it pairs with my Alnico II Tele pickups really well.
So, a genuine thank you to everyone who showed an interest, shared their knowledge and guided me through this. And, I didn't get zapped. (I did notice that warm tubes seem to drain the caps when the power is switched off, but I still connected my discharge tool to develop the habit.)
Wow, I'm ready to start my next build...
Sluckey, I'm thinking your Trem-O-Nator would be good with your AB763 Deluxe Lite.
« Reply #206 on: June 10, 2020, 05:29:49 pm »
call 1800gethelp if this becomes an addiction  :icon_biggrin:
« Reply #207 on: June 10, 2020, 05:55:31 pm »
what's that again? guitar amps? <click> buzzzzzzzz (dial tone).
« Reply #208 on: June 10, 2020, 06:21:56 pm »
Yeah, I might be nearing the slippery slope. I've actually been thinking about what I can sell off on eBay from my "real money pit" hobby, radio control airplanes, to fund another amp project. There's some money invested there, after 30yrs of collecting airplane stuff.
