September 15, 2026, 10:59:24 pm
Hoffman Amps Forum image Author Topic: Fender specific treble pots  (Read 5552 times)
Offline Leevi
    • Rikstone
« on: August 03, 2020, 11:27:06 am »
Custom Vibrolux reverb uses special treble pots.
https://el34world.com/charts/Schematics/files/Fender/Fender_custom_vibrolux_manual.pdf
Since it is difficult to find them is there any way to replace them any other value or just use standard 250KA pots?
/Leevi
Offline 66Strat
Re: Fender specific treble pots
« Reply #1 on: August 03, 2020, 11:52:54 am »
Weber has a 350K pot tapped at 70K, as used in the Blonde Showman and Bassman amps.
https://www.tedweber.com/wp354at
Regards,
JT
Offline brewdude
« Reply #2 on: August 03, 2020, 01:30:26 pm »
This was originally posted on the amp garage.
Offline Leevi
    • Rikstone
« Reply #3 on: August 04, 2020, 01:42:24 am »
The Custon Vibrolux Reverb uses 250K/50K taper. Maybe this 350K/70K workaround is close enough?
/Leevi
Offline Latole
« Reply #4 on: August 04, 2020, 03:42:31 am »
I'll use/ mod this circuit  : Custom 68 Vibrolux use B 250K pot ,( see first picture )no taper like the Custom Vibrolux reverb ( second picture) .
« Last Edit: August 04, 2020, 03:55:46 am by Latole »
Offline Leevi
    • Rikstone
« Reply #5 on: August 04, 2020, 08:45:15 am »
Yes,  this is one option
/Leevi
« Reply #6 on: August 06, 2020, 01:47:20 pm »
Custom Vibrolux reverb uses special treble pots. ... is there any way to replace them any other value or just use standard 250KA pots?
Weber has a 350K pot tapped at 70K ...
The note says "250k 20% tap" right?  So that's how we're getting "250kΩ tapped at 250k*0.2 = 50kΩ."
350kΩ * 0.2 = 70kΩ.  So unless you can buy the exact pot from Fender, just go for the commonly available 350kΩ tapped pot.
