September 18, 2026, 06:41:53 am
Hoffman Amps Forum image Author Topic: Marshall 2204 FX loop  (Read 5402 times)
Offline SoundCity85
« on: September 02, 2020, 02:06:52 am »
Hello,
I had great success with adding an FX loop to a DR103 preamp. Now I'm considering the same for a Marshall 2204 build. The only difference is that there is no free triode available, so I will wire in a new socket and two triodes become available for the loop. Looking again for the same concept, a level control pot on the outside, and a bypass switch. Can anyone suggest me a schematic? For the DR103 it was placed in between the treble pot and MV pot (https://el34world.com/Forum/index.php?topic=26300.0).
Best regards
Dominic
Offline Latole
Re: Marshall 2204 FX loop
« Reply #1 on: September 02, 2020, 03:47:26 am »
I'll use same circuit as the DR103
I'll put phase loop between Treble pot wiper side to the the side or Master Volume pot.
« Last Edit: September 02, 2020, 06:10:57 am by Latole »
« Reply #2 on: September 02, 2020, 11:45:45 am »
...a level control pot on the outside, and a bypass switch. Can anyone suggest me a schematic?...
Are you bothered about the loop flipping the signal polarity? I assume not, as the arrangement apparently used on your DR103 would have done that.
As you've now got 2 active devices, you've got more options, eg see the Merlin loops on that thread.
« Last Edit: September 02, 2020, 11:47:47 am by pdf64 »
Offline 2deaf
  • Now too deaf for 100 watts
« Reply #3 on: September 02, 2020, 10:08:45 pm »
Here's one.
