August 04, 2026, 01:11:06 am
Hoffman Amps Forum image Author Topic: Looking for Deluxe Reverb cabinet construction plans  (Read 14954 times)
Offline ululufut
« on: September 24, 2020, 07:41:38 pm »
I'm building a circuit into a Deluxe Reverb chassis that has a 5F6-A sized OT. I'm not sure if the OT is going to bump into the speaker, so I'd like to take a look at a cabinet diagram to see if I need to specify a custom baffle when I order the cabinet from Mojotone. Does anybody have a construction diagram available for this?
Offline Raybob
    • Tube-Tone Amplifiers
Re: Looking for Deluxe Reverb cabinet construction plans
« Reply #1 on: September 24, 2020, 11:50:25 pm »
Don't have diagram but I've squeezed in bigger transformers into DR boxes.  If that's a 4 bolt mount OT, best to use a cap can and loose doghouse to mount OT opposite end from PT.  Other option would be order a 2x10 baffle board.  If tranny is smaller, as in VIbrolux size, it can fit but must be mounted at an angle to clear speaker.
Offline Latole
« Reply #2 on: September 25, 2020, 04:07:50 am »
Send E mail to Mojotone.
Offline ululufut
« Reply #3 on: September 25, 2020, 11:13:30 am »
I've inquired with them in the past on a similar topic - chassis diagram - and there policy is that they don't distribute that kind of documentation to customers.
I live in a remote area, otherwise I could run to a local shop that has a Deluxe Reverb and take a measurement.
« Reply #4 on: September 25, 2020, 11:49:45 am »
May be as simple as choosing a speaker that will fit. I had to do that with a Deluxe Reverb that I crammed into a 5E3 cab.
Offline Latole
« Reply #5 on: September 25, 2020, 12:56:00 pm »
I know that, I mean send your chassis measurements and ask if it will fit.
Offline 2deaf
  • Now too deaf for 100 watts
« Reply #6 on: September 25, 2020, 01:05:44 pm »
I have a Mojotone cabinet here.  I will get you some dimensions after lunch.
Offline Latole
« Reply #7 on: September 25, 2020, 01:44:07 pm »
Great ! :worthy1:
Offline 2deaf
« Reply #8 on: September 25, 2020, 03:32:58 pm »
The Deluxe output transformer clears the speaker by 1/2 inch.  I believe the 5F6-A transformer is over an inch taller than the Deluxe, so the speaker would have to be moved over towards the Normal Input side.
Offline ululufut
« Reply #9 on: September 25, 2020, 05:33:23 pm »
Thanks! This is exactly what I was looking for. Problem solved.
Offline bnwitt
  • Crankin' out the tone.
« Reply #10 on: October 03, 2020, 03:21:50 pm »
See attached JPG and PDF
« Last Edit: October 03, 2020, 03:27:08 pm by bnwitt »
Offline ululufut
« Reply #11 on: October 04, 2020, 12:12:01 pm »
That's terrific - thank you!
Offline Archtop67
« Reply #12 on: April 20, 2022, 08:34:46 am »
is the pdf still available? I too am looking for cabinet plans for deluxe reverb after my mojotone amp build
Offline SILVERGUN
« Reply #13 on: April 20, 2022, 08:42:36 am »
The link in Reply #10 still works for me
