August 29, 2026, 07:29:07 pm
Hoffman Amps Forum image Author Topic: Stanby switch loud "pop"  (Read 15695 times)
Offline Latole
« on: November 05, 2020, 05:57:01 am »
Hello ,
I put all my vintage amps in order. Replacement of filters caps, bias cap, bypass caps, 3 progs cable, bias  etc.
I finished my Bandmaster AB763, the only thing I block and the very loud "pop" with the Stanby switch. I did all the known mods *; a resistance across the switch, a 0.047 capacitor and even a new switch. No success  :BangHead:
All mods* that works on my other amps .... except the Bandmaster.
Why ? And what to do ?
https://robrobinette.com/Generic_Tube_Amp_Mods.htm#Pop_Reduction   (fixed link... sluckey)
Thank's if you can help me
« Last Edit: November 09, 2020, 10:08:01 am by sluckey »
Re: Stanby switch loud "pop"
« Reply #1 on: November 05, 2020, 01:54:50 pm »
What value resistor, ie the 47k suggested by Merlin http://www.valvewizard.co.uk/standby.html
If it's still popping with that, then it's followed by a couple of alternatives.
Offline Latole
« Reply #2 on: November 05, 2020, 02:43:47 pm »
Thank's. I'll try these from Merlin and report ;
 A 47k 2W device is a reasonable compromise. You can also add a 100nF (or so) capacitor across the switch to reduce arcing inside it. It is hard to find (attractive) switches which are rated for high voltage use, especially DC voltage, so most people just use a suitably heavy-duty mains switch. Since the HT current is quite small (hundreds of milliamps, not amps), this does not seem to be a problem.
_________________________________
I don't want to put a bigger/ most powerful switch which need a bigger hole
Offline Latole
« Reply #3 on: November 06, 2020, 06:33:25 am »
I have tried Merin / wizzard's suggestions without success. 47 K  and  0.1 mfd cap. Always the "pop".
These are just about the same suggestions as Robrobinette
« Reply #4 on: November 06, 2020, 08:16:14 am »
I have tried Merin / wizzard's suggestions without success. ... Always the "pop". ...
On another forum, there are at least 30 threads that are 15 pages long each, bickering about Standby switches.  The best choice is don't use one and if it's already present on your vintage Fender, just leave it in Play mode.
Offline Latole
« Reply #5 on: November 06, 2020, 08:31:26 am »
AhAh no, it is too easy to give up
My question was ; All mods* that works on my other amps .... except the Bandmaster.
Why ?
Work on other Fender too.
« Reply #6 on: November 06, 2020, 08:43:04 am »
Hi-rez pics, especially STBY switch.
« Reply #7 on: November 06, 2020, 09:11:55 am »
Including the last 2, ie removing dc from the switch?
Does the pop occur when switching from play to standby, from standby to play, or both?
Offline Latole
« Reply #8 on: November 06, 2020, 09:22:01 am »
" Including the last 2, ie removing dc from the switch? "
No, I don't want to mod amp wirings
Pop : only from Standby to play , never from Play to Standby
« Reply #9 on: November 06, 2020, 09:36:11 am »
So it won’t be back emf from the choke, hence the 47k not helping.
How about if the tube in the phase splitter circuit is removed?
Offline Latole
« Reply #10 on: November 06, 2020, 11:05:39 am »
With PI tube removed Pop is more quiet
And any more Pop if I switch stanby on/ off fews times..
With PI in, always loud pop
What did it mean ?
Offline Colas LeGrippa
  • MAKE LOVE NOT WAR
« Reply #11 on: November 09, 2020, 12:47:15 am »
Swap the switch it migjt work.
P.S.: call me Alvin.
Offline Latole
« Reply #12 on: November 09, 2020, 03:43:04 am »
Read my top message ; ..... even a new switch. No success
« Last Edit: November 09, 2020, 05:15:00 am by Latole »
« Reply #13 on: November 09, 2020, 06:34:14 am »
What did it mean ?
Other than that standby is a stupid concept, I’m not sure  :icon_biggrin:
How about if the power tubes are removed?
Offline Latole
« Reply #14 on: November 09, 2020, 06:38:58 am »
Why not going to the best solution ; unplug speaker :laugh:
« Reply #15 on: November 09, 2020, 09:36:56 am »
doesn't matter who's method you use: you're kicking in a substantial inductive load that's connected to the speaker, stuff is gonna go pop. maybe not bang pop! but will have at least a low pop or subtle thump - but it's gonna make noise. deal with it! hi-fi stuff has a time delay relay for addressing turn-on thump, but with tube-amps we don't want infinity load.
if you want something less dramatic, then consider a mute switch on the PI input or if SE, the final preamp?
Offline Latole
« Reply #16 on: November 09, 2020, 09:41:26 am »
Why ?
I don't want to mod a vintage amp.
Thank you all, amp will stay like that
« Last Edit: November 09, 2020, 09:45:24 am by Latole »
« Reply #17 on: November 09, 2020, 09:46:28 am »
Which switch are you using? Post a pic.
Offline Leevi
    • Rikstone
« Reply #18 on: November 09, 2020, 09:46:50 am »
I have used this component succesfully to remove power switch pops. Standby switch works with DC but try to serial connect cap and resistor across the switch.
https://datasheetspdf.com/mobile-datasheet/PMR209.html
/Leevi
Offline Latole
« Reply #19 on: November 09, 2020, 09:53:13 am »
I have a lots of good switches, many brands, some original for Fender. some more powerfull ( too big to fit anyway)  none work.
I often fix this issue on many amps with new switch and / or capacitor only, with success.
Thank you.
Offline Latole
« Reply #20 on: November 09, 2020, 09:54:43 am »
/Leevi
Did you test it on a Bandmaster ?
Offline Leevi
    • Rikstone
« Reply #21 on: November 09, 2020, 09:59:38 am »
No, what is special with Bandmaster (what circuit)?
/Leevi
Offline Latole
« Reply #22 on: November 09, 2020, 10:03:04 am »
/Leevi
I gave all this information when opening the post : AB763
Offline Latole
« Reply #23 on: November 09, 2020, 10:12:21 am »
Thanks everyone for trying to help me.
I reassembled the chassis in its case. I leave as is.
« Reply #24 on: November 09, 2020, 10:13:35 am »
I don't have any objectional pop with my '67 AB763 Bandmaster. I wonder if there's something wrong with the original rectifier board? Maybe try this...
Disconnect HT leads and B+ wire from rectifier board. Connect these three wires to a temporary rectifier that is floating in air. Any joy?
Offline Leevi
    • Rikstone
« Reply #25 on: November 09, 2020, 10:13:42 am »
OK, Bandmaster circuit (AB763) as such is not the root cause for the pop. There must be some other issues causing it.
Have you tried the PMR209?
/Leevi
« Last Edit: November 09, 2020, 10:16:19 am by Leevi »
Offline Latole
« Reply #26 on: November 09, 2020, 10:21:04 am »
/Leevi
No.
Offline Latole
« Reply #27 on: November 09, 2020, 10:25:29 am »
  I'll try.
My B+ read at least 425 volts if I remember, with no ripple. If something wrong with rectifier I should read low B+ no ?
« Reply #28 on: November 09, 2020, 10:45:22 am »
It's normal to have about 5 to 10V ripple at the output of the rectifier. My idea is that the original board may be conductive and causing problems. I don't really suspect the diodes, but my suggestion would eliminate the diodes and the board as possible culprits. May be a solution. May be a waste of 5 minutes. But at least you'll know.  :icon_biggrin:
This is just a wild ass guess but it's easy enough to try. Maybe a bit more difficult since you have put the chassis back in the head. I hate putting that last nut on the chassis screw that's behind the PT.
Offline Leevi
    • Rikstone
« Reply #29 on: November 09, 2020, 10:57:43 am »
Sounds so familiar😁
/Leevi
Offline AmberB
« Reply #30 on: November 09, 2020, 10:55:39 pm »
That last nut is really fun on a late 60s silverface 50 watt Bassman...
Offline Latole
« Reply #31 on: November 10, 2020, 05:34:51 am »
Same loud pop !
Try another switch, I have a lot of them, different brand ; same pop
« Reply #32 on: November 10, 2020, 05:55:37 am »
+ 1 for Leevi's suggestion
it is'nt an expensive component
so give a try to a PMR209.pdf
Offline Latole
« Reply #33 on: November 10, 2020, 06:12:59 am »
 It 's  metallized paper with integrated resistor • 0.047 – 0.47 μF, 22 – 470 Ω,
I built something like that as suggested before with Robrobinette link
