September 08, 2026, 01:13:58 pm
Hoffman Amps Forum image Author Topic: Mystery Amp  (Read 8781 times)
Offline cincyjack
Mystery Amp
« on: December 05, 2020, 01:11:54 pm »
Greetings tubeheads.
I’m a novice with an inherited little mystery amp that I thought might be fun to spruce up, if necessary. Easier to start with a kit but I’m hoping there are some basic things to be learned from this freebie.
I understand all the caveats and risks of working with tube amp electricity.
The amp in question worked the last time I fired it up years ago. I was told it’s a silvertone. The chassis is unmarked in a homemade case.
Closest I could fund was a silvertone 1449. Whereas the 1449 calls for a 6V6GT, the amp at hand has a 6BQ5. The other tubes are similar: 12AX7 x 2, 6X4.
http://schematicheaven.net/bargainbin/silvertone_1449.pdf
Transformer nums are:
TF 509-0
-606-541
TF102-P
606-542
I’d like to identify the amp and find the schematic.
At a minimum, I want to replace the two prong power cord, which I will address in a seperate post if I need help. Ideally I could test the components and replace those out of spec but realize that may be wishful thinking. If it powers up, prob a good idea to check the bias.
Any ideas for identifying this unit would be appreciated.
Re: Mystery Amp
« Reply #1 on: December 05, 2020, 01:49:16 pm »
Much bigger pics would help identify this amp but I suspect it's this Gibson...  Even the chassis layout looks the same.
     https://el34world.com/charts/Schematics/files/Gibson/Gibson_skylarkga5t.pdf
I suggest to just plug it in and see what happens before replacing anything. No need to check bias on this simple cathode biased amp.
Offline cincyjack
Re: Mystery Amp
« Reply #2 on: December 05, 2020, 02:01:56 pm »
Cool!
Thanks sluckey. I’ll have to research that amp.
Offline cincyjack
Re: Mystery Amp
« Reply #3 on: December 22, 2020, 02:25:49 pm »
Just for the record, this amp turns out to be from a Kalamazoo Model 2.
Nicer schematic!
https://irationaudio.files.wordpress.com/2016/10/kalamazoo-model-2-schematic1.jpg
