September 16, 2026, 09:41:57 pm
Hoffman Amps Forum image Author Topic: Filament wiring to jewel lamp that is entirely outside the chassis.  (Read 8372 times)
Offline Jatchley
  • i haven't been shocked yet.
Hello so I’m building a project amp and I’m curious what you genius people would do in this situation. Will the twisted filament wires be extra susceptible to EMI if they exit the chassis? Or is the twist good enough? The PT has a filament CT so I don’t have to worry about the filament resistors. The only part that is entirely outside the chassis in reference to the filament wiring is the lamp.
« Last Edit: December 08, 2020, 09:45:51 am by Jatchley »
Online sluckey
Re: Filament wiring to jewel lamp that is entirely outside the chassis.
« Reply #1 on: December 08, 2020, 10:13:28 am »
Still got 70VAC?
Offline Jatchley
« Reply #2 on: December 08, 2020, 10:16:03 am »
Still got 70VAC?
LOL oh! i forgot about that post. NO. i was referencing to ground not neutral.
Online sluckey
« Reply #3 on: December 08, 2020, 11:33:24 am »
Still got 70VAC?
The variac power switch is probably on the neutral rather than the line. If it were mine, I'd fix that.
Offline Jatchley
« Reply #4 on: December 08, 2020, 12:48:53 pm »
Still got 70VAC?
I’ll open it up and see what’s up. So any advice on this lamp?
Online sluckey
« Reply #5 on: December 08, 2020, 01:04:03 pm »
I was waiting for the geniuses to chime in. Meanwhile...
Offline Williamblake
« Reply #6 on: December 08, 2020, 01:21:11 pm »
I guess this means old radios got away with it but nobody knows where your out-of-chassis-filament-winding is going exactly.
Offline Jatchley
« Reply #7 on: December 08, 2020, 03:00:44 pm »
Haha wow! So I guess it’s totally fine?
Offline Jatchley
« Reply #8 on: December 08, 2020, 03:10:48 pm »
to a jewel lamp That doesn’t have the lugs inside The chassis. Every amp I’ve seen has the entire length of heater wires inside the chassis... that’s why I asked. This project has the lamp and it’s lugs outside the chassis. I wasn’t sure if the full shield of the chassis around them was needed to keep noise down. The design seems to me like it might have some noise issues to be addressed but I thought about it as a possible issue but wanted to confirm if it was frowned upon or not. Sluckeys example makes it seem like it’s no big deal...
Offline acheld
« Reply #9 on: December 08, 2020, 09:33:49 pm »
Those wires seem awfully exposed.
I guess if this was a project for my basement, and only my basement, then ok.
But I would not let a project like this out into the wild . . .   Yes, I get it that these are heater wires, low voltage, but I have seen crazy stuff happen, and would not take the risk.
As to noise, I doubt that the relatively low current AC outside the chassis would inject noise.   On the other hand, those wires could set up a great antenna.    You might just hear the Stones pulsing your heaters!
« Reply #10 on: December 08, 2020, 10:35:57 pm »
It's a risk.
I wouldn't wire it outside the chassis.
Online sluckey
« Reply #11 on: December 08, 2020, 10:42:07 pm »
Those wires are more than adequately protected once the chassis is mounted in the cab. It's a table radio! Was never meant to be in the wild. Millions of radios and other electronics from that era ran filament wires outside the main chassis for indicator lights, dial lights, tv tuner lights, etc. Lot's of other wires too. Heck, they even ran B+ wires to the speaker! An antenna coupled to the filaments, coupled into the signal path? Not likely. You ain't gonna ever hear Stones pulsing your heaters! However, I have heard music being reproduced in long blades of grass.   :icon_biggrin:
This was a restoration turned conversion project that started in the '60s, was forgotten, and finally completed in 2012. I posted that pic just to show Jatchley that it can safely be done, especially in his case where it's a short run to his faceplate.
Here's the rest of the story....  http://sluckeyamps.com/RCA/RCA.htm
Offline Jatchley
« Reply #12 on: December 08, 2020, 10:46:20 pm »
It's a risk.
The lamp? I know the current is high. This is why I was asking. That contraption will be inside a wooden head cab rack case. I was going to heatshrink the pilot lugs after soldering over to prevent shock risk. Input signal and reverb wires will be shielded cable. All those leads sticking out are just trafo/choke wires I didnt run inside yet or hook up yet. But it is a noise risk?
Online sluckey
« Reply #13 on: December 08, 2020, 10:58:57 pm »
There is no risk of noise. And if done properly, there is no safety issue.
EDIT... And a #47 bulb only draws 0.15A
« Last Edit: December 08, 2020, 11:02:22 pm by sluckey »
Offline AmberB
« Reply #14 on: December 08, 2020, 11:29:28 pm »
All of the Bogan CHB-35 PA amps, and the Lafayatte PA amp that I've worked on all have their power indicator lamp mounted outside the chassis, with the twisted wire pair running to it.  I would say that it was pretty common back when tube powered products were being made.
Offline j_bruce
« Reply #15 on: December 09, 2020, 04:25:03 am »
I recently rehabbed a Gretsch Dual Bass that had the pilot light outside the main chassis mounted on a face plate. It was a similar arrangement to the one Sluckey showed for a radio except that the pilot light and PT were on the same end of the situation so the wiring was only 4 or 5 inches. It still had the original lamp cord and is as quiet as can be and has a great tone.
« Reply #16 on: December 09, 2020, 03:58:52 pm »
Morgan (amongst others) do this in their amp cabs without a problem.
Makes for convenience if you have a banana-type 2-prong male/female plug to easily disconnect the lamp from the chassis 6.3VAC supply wire when hauling the chassis in and out of the cab.
