September 18, 2026, 06:39:43 am
Hoffman Amps Forum image Author Topic: Anti-vibration mounting do it yourself  (Read 8441 times)
« on: December 23, 2020, 10:16:05 am »
I've just seen this DIY anti-vibrating mounting solution and I've find it nice
think to those circuits that uses pentodes in V1
so I want to share with you
(ORings can also be the black version and the number can be set at your require)
Re: Anti-vibration mounting do it yourself
« Reply #1 on: December 23, 2020, 10:37:45 am »
Very heavy Rube influence. I'll wait to see pics of your first project to use this. Actually, I'd like to see any pics of a real project that uses this.
« Reply #2 on: December 23, 2020, 10:50:53 am »
 :laugh:
my 1st impression was the latching mechanisms that hold a rocket before launch
« Reply #3 on: December 23, 2020, 01:55:04 pm »
I think you can play with the numbers of the O Ring and also with the kind of O Ring
at the same diameter they can be more or less sturdy
As is in number of O Ring and dimensions it seems it is planned more for an HiFi amp than an instrument amp
My next build, if required, will have a different solution (planned some time ago)
something like this
I must specify that for Noval sockets I've rubber mounted Geloso NOS sockets
the problem is to find Octal anti Vibration sockets
looking for a very log time for them
I've find only one time a pair of very nice ones, but also very expensives and didn't got it
« Last Edit: December 23, 2020, 02:16:27 pm by kagliostro »
« Reply #4 on: December 23, 2020, 02:39:57 pm »
Fender did it like this in the '50s...
     http://sluckeyamps.com/harvard/h02.jpg
« Reply #5 on: December 23, 2020, 02:54:20 pm »
Many Thanks Steve
Offline Latole
« Reply #6 on: December 24, 2020, 03:40:56 am »
Why the need these anti-vibration mounting ?
You want to built a tubes amp to use on a Off -road truck ?
Why not hang the frame in the cabinet with 4 big rubber or springs?
« Reply #7 on: December 24, 2020, 06:23:33 am »
 :laugh:
that's how we did turntables at Sea,
fast-forward to the early '90s, used the method again with portable CD players and off road jeeps  :icon_biggrin:
Offline Latole
« Reply #8 on: December 24, 2020, 06:35:10 am »
:laugh:
That's it !
Why to re-invent the wheel?
« Reply #9 on: December 24, 2020, 09:12:30 am »
not all wheels work "the same"
I blew out a 33" on my jeep and had to drive 3 hours on the stock 26" spare.  top speed ~~ 20mph and even the gimbaled CD player didn't like the KAthunk, KAthunk as I rolled on down the road  :icon_biggrin:
Offline Latole
« Reply #10 on: December 24, 2020, 01:49:00 pm »
You talk about tires, not wheels
« Reply #11 on: December 24, 2020, 07:39:59 pm »
Try a 6SJ7 as V1 on a combo .....
Offline Latole
« Reply #12 on: December 25, 2020, 03:28:32 am »
Thank you to answer,
 I never had to use these tube, I did not know.
« Reply #13 on: December 25, 2020, 03:21:14 pm »
what we ended up with for shock mounting - the socket used is a NOS amphenol top-mount with a very thick body. the amp is a parallel 6V6 SE based on the 1948 supro: same amp in this DSE thread. the cork actually helps with resonance/microphonics. that meatball RCA 6SJ7 tiene mucho mojo amigos. the mismatched 6V6 add some character to the tone. the OT is an Edcor USA made GXSE 2.5KΩ:4Ω model before they started using end bells on the entire GX line.
https://www.dropbox.com/s/t84gmnjzy58592y/DSC01253.JPG?dl=0
« Last Edit: December 25, 2020, 03:29:09 pm by DummyLoad »
