August 29, 2026, 07:28:59 pm
Hoffman Amps Forum image Author Topic: Ampeg Portaflex B12-XY ?s  (Read 4755 times)
Offline waldner
  • I REALLY DO love tube amps
« on: January 27, 2021, 09:27:42 pm »
Anyone familiar with the Ampeg Portaflex B12-XY?  3 questions:
1.  The vibrato seems to only work on input/channel 1 and not on input/channels 2 and 3.  Is this how it is supposed to be?  It’s odd because channel 1 is higher gain and more crunchy while 2 & 3 are more clean lush sounding, which you would think is more ideal for the vibrato.
2. The reverb is also kind of odd in that it connects to a small external speaker.  If there is room I was thinking of mounting an 8” or 10” speaker in the existing cabinet and feeding the reverb signal there instead.  Does that make sense?
3. There is a separate horn tweeter which I was thinking of removing or defeating as I don’t think all those very high frequencies are really needed for guitar.  Any problems with doing that?
Thanks in advance for any help.
Re: Ampeg Portaflex B12-XY ?s
« Reply #1 on: January 27, 2021, 09:50:23 pm »
... Ampeg Portaflex B12-XY?  ...
Yes, the schematic (which may not exactly match your amp) shows the vibrato on one channel but not the other.  Jacks 3 & 4 of the schematic feed a channel with only 2 gain stages (and no vibrato).  Jacks 1 & 2 add an extra 6 gain stages to create & mix the vibrato.
I haven't played an amp with one of these circuits, but I hear it's not great at producing actual "vibrato."  I haven't analyzed the circuit, but what was claimed was the circuit sought to create a lot of 2nd harmonic distortion, then wiggle that and mix it with the original signal.  Makes sense if you felt such a circuit sounded "gainy."
Certainly you can do that.  Ampeg had something similar in the Echo Twin amps (except those were 2 full Rocket amps in one cab, each with their own speaker & reverb feeding the 2nd Rocket amp).
Sano also tapped signal off the main amp's speaker to drive the tank, amplified it with a small single-ended amp, and then fed reverb-only to a 8" speaker next to the main amp's 15" speaker.
No problem.
Offline waldner
« Reply #2 on: January 27, 2021, 10:45:04 pm »
Good info.  Thanks HBP.
